Author Topic: XS650 Gentleman's Express  (Read 11008 times)
Offline Scott S
Re: XS650 Gentleman's Express
« Reply #25 on: November 03, 2012, 06:12:48 PM »
 And got the engine installed today. Swapped over the Pamco (still have to connect the wires) and installed the carbs.
 Just have to put on the air filters, breather and exhaust. I still need to put the electric starter on, too. I plan on cleaning up the windings first, though.
 And speaking of breather....I picked up the parts the other day.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #26 on: November 04, 2012, 06:25:00 AM »
Motor looks great
Offline Scott S
« Reply #27 on: November 04, 2012, 02:19:00 PM »
 Breather system installed. I neatened it up and have it running closer to the battery box. Brake booster check valve and breather filter.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #28 on: November 04, 2012, 02:56:19 PM »
 Hmmm....what could these be? Pulled these out from under my bed where they've been in storage for a few years.
 MikesXS Commando exhaust system.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #29 on: November 04, 2012, 02:57:57 PM »
 Got them installed today. Still have to line them up, make sure they're even, etc. Just need a couple of bolts for the rear hangers. These were for the '78-83 Specials and this bike is a '78 Standard, so the rear hanger hardware is a little different than what I have.
'71 CB500 K0
'81 Yamaha XS650
Offline BeSeeingYou
« Reply #30 on: November 04, 2012, 05:18:10 PM »
Have a friend who has those on his 83 XS650.  They sound great.
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #31 on: November 04, 2012, 09:17:13 PM »
Rear turn signals mounted. Only now did I realize that I mounted the front signals "upside down", with the screws showing. I'll have to go back and fix that.
 A To anyone running these signals: Did you have to change the stock flasher?
I've used those blinkers before on several bikes. You Sir, have good taste 8) Mine all were aluminum and I never had any problems even on a CB450 Twin with very stiff suspension. The Honda flasher works, I use the $2 automotive flashers. They fit everything so keeping spares is easy.
But they will rattle apart if you don't insulate them from the frame/vibration. I wrap them in foam pipe insulation like you use on house plumbing.
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Offline Scott S
« Reply #32 on: November 05, 2012, 03:30:15 AM »
 Wrap what in foam insulation? The signals themselves? The stock XS turn signals are rubber mounted (hey...it's a big twin. It vibrates. A lot.), so these are mounted using the XS grommets.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #33 on: November 08, 2012, 12:41:50 PM »
She lives! The clutch is slipping. Wish I had checked that before adding oil but, Oh well. I have a stack of plates to pick through and I'll get that sorted. That, and a non-working hi-beam and tail light (brake light works....probably just the bulb), she's almost ready to ride again!
XS650
'71 CB500 K0
'81 Yamaha XS650
Offline knowsnothing
« Reply #34 on: November 08, 2012, 02:42:13 PM »
Nice!  Bike looks great Scott!
1978 CB750k Blue - for sale
Offline BeSeeingYou
« Reply #35 on: November 08, 2012, 10:09:58 PM »
Sweet sounding bike.  Still my favorite vintage Japanese bike.
« Reply #36 on: November 08, 2012, 10:24:56 PM »
Very nice mate, I've had a soft spot for one of those since they were new. Maybe soon........ ;D
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #37 on: November 14, 2012, 02:13:58 AM »
Sorry for being slow to reply and being a little vague.The old automotive type turn signal flashers are round, about 1-1/2 x 1 inch or so. If they don't fit (or if you don't have) the stock mount then they are just hanging by the wires under the seat or sidecover and they get banged around and fail. So the relay get wrapped, not the lights ::)
Member#2815
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
Offline Scott S
« Reply #38 on: December 01, 2012, 03:44:58 PM »
 Well, the clutch was "slipping" because of a busted up clutch basket! When Dad and I unloaded the replacement engine from the back of his truck, it took a slight tumble to the ground. We caught it, or so we thought, and it was a gentle lay-down.
 Turns out we busted up the clutch basket. I'm really lucky that it didn't explode when I was riding it!
 This one ear was bent and not allowing the plates to move. We tried moving it back knowing full well it would break....and it did.
 It was until we removed the basket that we saw that the rear of the basket had a crack as well.
 Pulled the basket from the other engine and installed new plates (even though the ones in the engine measured out perfectly fine....it was the damage to the basket causing the problem) and now it all works perfectly.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #39 on: December 01, 2012, 03:49:06 PM »
I decide to keep the stock seat. Also installed the mirrors and swapped out the speedo for one with a working trip-meter. I also changed out the tach and speedo buckets for a couple of better units.
 Traced the wiring problem for the tail light and fixed that. The high beam doesn't work because I never wired it up! Remember....when I first built this bike, I used the '78 harness and '75 controls, switches and gauges. I just never spliced in the wires for the high beam. On the To-Do list....just need to make time.
 Here are some pics from today.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #40 on: December 01, 2012, 03:50:51 PM »
 I think I'm going to hold off on the fork brace and Brembo conversion for now. Plans are to get a tag and insurance and enjoy it as-is for a little while.
'71 CB500 K0
'81 Yamaha XS650
« Reply #41 on: December 01, 2012, 04:40:06 PM »
Looks nice.  How's it running?
« Reply #42 on: December 01, 2012, 08:44:18 PM »
That is a beautiful bike, I've never owned one, so I think I'll start looking. Cheers, Terry. ;D
Offline CycleRanger
  • No comment about being an
« Reply #43 on: December 01, 2012, 08:53:36 PM »
It looks great!  I've need to force myself to finish restoring my CJ360 so I can get on to my XS650.
It looks good but it sat for more than 10 years before I got it.
« Last Edit: December 01, 2012, 09:01:10 PM by CycleRanger »
« Reply #44 on: December 01, 2012, 09:24:07 PM »
Geez, that's a nice one too! I think I'm jealous, or at least, envious.......... ;D
Offline Scott S
« Reply #45 on: December 02, 2012, 04:34:50 AM »
 Runs great. As soon as I get it tagged and can put a few miles on it, I'll check the timing and synch the carbs. Not because of any issues....just because I haven't done it yet. They were both set static or on the bench.
'71 CB500 K0
'81 Yamaha XS650
« Reply #46 on: December 02, 2012, 06:55:55 AM »
Have you attempted start up yet?
Offline CycleRanger
« Reply #47 on: December 02, 2012, 07:15:54 AM »
Nope, haven't really touched it. Just made sure it wasn't seized. The PO drained the tank and carbs when he parked it.
It sat covered in a garage from about 1999 until this year. It can sit a little longer.  ;)
Offline Scott S
« Reply #48 on: May 11, 2013, 04:26:20 PM »
Some recent pics.
'71 CB500 K0
'81 Yamaha XS650
« Reply #49 on: May 11, 2013, 05:18:43 PM »
Looks great mate, and better (in my opinion) than the one beside it in pic 1. Cheers, Terry. ;D
