Yes, supersensitive on my home made. Very good explanation, and no I did not get even tubes of oil - when I finally got #1 to behave and not drop ( the effective region of turn on the slide screws was about 1/4 to less than 1/2 a turn, or that particular oil tube would sky up, or drop and bubble it all).
So yeah, with home made it was a hassle in the sense I hard to start and kill it 100 times till I got them dialed in close enough.
I only had it running for maybe 60 seconds once while I took a pic - the oil tubes were 1" to 2" apart I'd say and not even.
My 750 is not rebuilt nor are new parts in use ( plugs, caps, wires, dyno ign - yes) that would affect this system other than those.
I hacked the carb together even made some o rings with some spin sanding.... so I definitely think someone could do better - slide #4 screw and tab part are twisted on top...
Let me just say though I took a run late last night when I was finally done and it is a huge world of difference - my handlebars do not buzz, the mirrors are not shaking unbelievably - and I could chug it in 2nd gear coming in not touching the throttle and she just tugged and tugged and kept going - no stalling, no couching and crappy jerky throttle... it was smooth and very enjoyable...
Here's another twist I cannot explain - I synced it once yesterday after valve lash check, then came back after car errands - when starting I heard a tick in head - thought maybe I didn't tighten down a rocker set net... so with the carb tuning on it, I redid the valve lash check... then back to a few HOURS of screwing with the carbometer...
Finally finished up late after 10pm, and get stuff put away a bit and I see #1 spark plug wire resting on the coils where I put it when redoing the valve re-check.
Well, I had it stable a few different times, not sure how with a gas washed non firing cylinder - not sure how I didn't notice other than runs were only a few seconds at 1500 or below... LOL
Guess I had better take another stab at it with all plug wires on...
- in any case it ran fuhhhreaking great ! I mean night and day difference.
Okay shaggy dog spew over.
