Damn Frank, you need to change the filter in that washer!
MUCH cheaper than replacing 10 gallons of cleaner. LOL. I keep kerosene in mine at a lower level than you do. The pressure was diminishing so I turned the filter upside down and viola, I was spraying kerosene all over the place
The top half of the original filter was basically new. Mine looks identical to yours'. Harbor Freight.
Keep plugging away. I'm sure Bill will still be piddlin with his in FL
and we can work on yours too! Shouldn't take more than 1 case of beer. What's the problem with #3 look like? I can bring one spare brown with me should you need. I had greens all the way across until 'the damage' occurred and smoked the middle journal. I then upped it to brown and ended up with black there after the crank work.
