Author Topic: Starting Fluid  (Read 2075 times)
Salem350F
Starting Fluid
« on: May 13, 2005, 10:05:26 AM »
I read time and time agiain about the use of statrting fluiid.  I would use caution with its use.  I have seen lots of damage on engines especially the top ends and actually destroyed engines by  liberal use of the stuff. I have ruined 1 in my day-that was enough for me  I used to make my living as an Aircraft Mechanic ( I have and A& P liicense) and have seen plenty of destroyed engines I also used to sell parts to PennDot garages and there the guys would use cases of starting fluid to start everything.  The aircooled engines suffered the worst, lawn mowers and the bigger twin cylinders on garden tractors would seize up.  Remember the ether is a solvent and washes away any top end lubrication and especially the cyclinder walls.  On a fresh rebuild lots of lubrication is wanted on the cylinder walls and the starting fluid just washes it away. I have seen guys try to keep the engine running on starting fliud and just squirt away into the intake as the engine revs along. Makes me shutter!  I wouldn't say a little squirt will hurt, but remember that starting fluid was meant to be an aid to starting a below zero temps when gasoline doesn't want to vaporize. If the engine will not start and run something isn't right, remember that fuel fire and compression make the engine run if it is right the starting fliud is just a cover up,find and  fix the problem.  I personally think that the starting fluid causes alot of unessecary engine wear, I know when I get frustruated I want to reach for starting fuild but I haven't had any  in my shop for years, just to avoid the temptation.
Offline kghost
Re: Starting Fluid
« Reply #1 on: May 13, 2005, 10:08:29 AM »
Right on man. Your almost better off with a little squirt can of gas.
P.S. Also an A&P. Seems to be lots of the aviation types lurking here.
Stranger in a strange land
Salem350F
Re: Starting Fluid
« Reply #2 on: May 13, 2005, 10:14:49 AM »
I guess we are here because we are motor heads through and through!!
Offline Hondell
  • Just an easy 1000 Hr. resto
Re: Starting Fluid
« Reply #3 on: May 13, 2005, 12:57:49 PM »
Believe it or not WD40 makes a great starting fluid. Offers some lubrication and less volotile. Been using it for years on my lawnmower.
Rick
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline cb650
Re: Starting Fluid
« Reply #4 on: May 13, 2005, 03:22:48 PM »
Read some where long ago that almost 70% of pilots ride bikes.  Much more than GP.
               Terry
