Hi team,
Electrical gremlins have struck again on my CB750 F2 'devils bike'.
History - melted earth wire after starting, lots of smoke. Got second hand wiring harness as you can't by new ones for the F2. Replaced the rectifier and I think regulator due to melted wiring. Stator and field coils tested within tolerance. Cleaned terminals of harness, earth strap at the frame and added an extra earth wire from where the rectifier bolts onto the battery box to where the tool kit carrier bolts on to frame under the seat, read it in HMs book however he said to near the seat like on the K1 bolt hole near the latch.
Fully charged battery, started up and tried to measure voltage with DMM across the battery. The reading on the DMM wasn't stable and I was unable to obtain a reading. I don't have an analog meter to try the test. I then changed where I took the voltage, still on positive terminal but the black wire from DMM to various points on the bike, still the same unable to get a stable reading as it was changing so quickly I think the DMM was having trouble trying to keep up with it. Voltage with ignition on and not running is 12.52 - Dyna S ignition, green 3 ohm coils, headlight on low beam - pretty much standard voltage from tests years ago if I remember. Start the bike and up the rpm to 1900-2000 and I can then get a stable reading 12.79 volts.
Several trips to work and back about 30 mile round trip, one morning press the starter and nothing, lights on so kick start the bike (one thing I do like about these old machines) and away we go. Voltage up to 13 volts. Get home bike running so get the DMM and measuring 10.2 volts and on the decline. Crap. Cause stator coil wire nearly snapped off. Changed stator out completely with new one, field coil tested good. Put it back together and now same issue at idle, can't get a stable voltage reading at battery and now rev it up to 4000rpm and watch the voltage climb to 17 volts. Gee just as well I was patient and tested it all. Too early to start it up at the moment, I've just changed voltage regulator. If this doesn't fix the problem, what else am I looking at as the problem with voltage at idle. I never had this problem before the earth wire melted (the one that attaches to the frame under the coils, common fault I've found from looking on this forum). Oh and I did a diode test on the regulator, a diode or 3 bad and on their way out as getting reading on the earth side doing the test...have I just unknowing discovered the problem? Just remembered that then. I'm running out of spares and I don't think I've got a spare regulator actually I'll take the one off the K1, I know it has a dodgy diode as well. 40 plus years, somethings bound to give and it's not me haha.
I do apologise for the long comments, however I'm trying to give you all the information straight up, and I'm sure I've forgotten something. Thanks.
