Author Topic: Rearset brackets  (Read 1722 times)
Offline afkrejci90
Rearset brackets
« on: October 25, 2012, 02:34:41 PM »
I plan on using new rearsets, either universal or some type off a cbr.  Does anyone make brackets so its possible to move them back away from a stock location.  Or would it be easier to fabricate your own?  By the way I'm looking for something to fit a 78 750K
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
Offline Dimitri13
  • 1974 CB550K
Re: Rearset brackets
« Reply #1 on: October 25, 2012, 03:50:40 PM »
Raask and Tarozzi have rearsets that I know of. I'd recommend Tarozzi rearsets from FastFromThePast. That's where I got mine and I had a wonderful time dealing with them. Excellent communication and customer support.
Offline liPPy
  • 1978 cb750k
« Reply #2 on: October 25, 2012, 04:41:09 PM »
Tarozzi rearsets won't work with a 78k.
Raask will - bolts on but you have no height adjustability which may or not be a problem depending on how tall you are.
If you want to use universal rearsets then you will have to fab brackets of your own.
Do a search. There are a ton of posts about this. Here's a good start ;)  http://forums.sohc4.net/index.php?topic=43906.0
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: October 25, 2012, 08:16:42 PM »
Ah, my mistake then. You'd think there would be one, lol.
Offline Dyrden
« Reply #4 on: October 25, 2012, 10:00:08 PM »
This is a 77 frame with Tarozzis that are height adjustable.
Untitled by bailey_james62@ymail.com, on Flickr
Offline liPPy
  • 1978 cb750k
« Reply #5 on: October 26, 2012, 06:45:24 AM »
What I should have made clear is that the Tarozzis do not bolt on to a 78. Fabrication work of some description is required.
Dryden - I've long admired your build and rearset bracket. It's so clean and neat. Genius!
