Author Topic: 77 750K PD Carb Rebuild  (Read 655 times)
Offline cl4yd0h
« on: November 03, 2012, 09:38:20 PM »
Hello, great forum! I have been using a lot of the resources here lately, thanks for everything!
Quick question on the carb rebuild kits. It came with 5 o rings. I understand the two large rings go on the fuel rail but where do the other ones go? The only other I find is an o-ring on the bowl drain but the new ones seem to be too large.
Sorry for the silly question, I can't seem to quite find what I'm looking for.
Thanks for any insight.
Offline cl4yd0h
Re: 77 750K PD Carb Rebuild
« Reply #1 on: November 05, 2012, 02:02:53 PM »
Well, After I put it all together and found a major leak on top of carb 2 above the accel pump, I found out one goes there.
Another, In the mixture screw and another on the drain screw.
Hope someone finds this useful.
Offline mono
  • Definitely no
« Reply #2 on: November 05, 2012, 03:17:11 PM »
Thanks for the follow up!  Prob didn't get any responses because there was no pic.   Really helps us help you.
Sent from my SPH-L710 using Tapatalk 2
