After doing the other fork leg last night I would say be sure to sand out all the scratches from the initial sanding. I started on the second leg with 100 grit then moved to 220, 600, 1000, 2000. I should have either spent more time with the 220 or maybe had a 150 in between. I just couldnt get the finial polish to look as good on it and I think it was because of the rough initial sanding.
