Author Topic: Ashes to ashes ...  (Read 8219 times)
Offline Sara
  • Be different, be yourself
Re: Ashes to ashes ...
« Reply #25 on: December 04, 2012, 04:27:00 AM »
Thanks Rob.
And Funnyjimmy, the forks are Paioli's. From a Ducati, i think.
Sara
Offline Sara
« Reply #26 on: December 12, 2012, 09:41:18 AM »
Good news, just got a email from Rob that my seat is ready for shipment  :)
And i "quickly" made some rearsets  ;)
Sara
Offline Sara
« Reply #27 on: December 28, 2012, 10:22:01 AM »
I know what I'm doing tomorrow. I received the seat from Voxonda and will make some brackets to weld on the frame. :) And fit some tires, and a bracket for the steeringdamper, and a fairing support, and adapt some alloy sprockets, and .... ;) Oeps, seems that Saturday don't have enough hours in it. :)
Happy newyear and best wishes to all.
Sara
Offline Jim F
  • go baby go
« Reply #28 on: December 28, 2012, 11:01:23 AM »
you go girl...............must be a machinist
2002 RC51 1000 (SP2)
1983 GS1100EC Suzuki
1992 KTM500 2 stroke
1975 CB750/836 Honda
1978 GS750/840 Suzuki
Offline Sara
« Reply #29 on: December 29, 2012, 10:39:18 AM »
steeringdamper: check
Offline Sara
« Reply #30 on: December 29, 2012, 10:40:30 AM »
brakedisks (big ones): check
Offline Sara
« Reply #31 on: December 29, 2012, 10:41:57 AM »
seatbrackets: check
Offline Sara
« Reply #32 on: December 29, 2012, 10:44:09 AM »
fueltank finished + brackets: check
exhaustbracket: check
Offline Sara
« Reply #33 on: December 29, 2012, 10:47:53 AM »
new Avon tires: check
Take them and the rims to work, much easy-er to do then at home with tyreleavers.  ;)
Offline Sara
« Reply #34 on: December 29, 2012, 10:49:26 AM »
fairing tryout: check
Offline Sara
« Reply #35 on: December 29, 2012, 10:50:55 AM »
rear sprocket adapted: check
Offline Sara
« Reply #36 on: December 29, 2012, 10:57:11 AM »
brake calipers: not good. These brembo's are to wide and touch the spokes of the front wheel. Luckily there where some brakepistons missing and i didn't ordered them yet. ;)
I think i need some of a Bmw K75 or K100.
Small setback, without money lost, got them for free.
All by all, a very busy Saturday.
Sara
« Reply #37 on: December 29, 2012, 02:13:30 PM »
Very impressive. I assume you have help? that seems lime a lot for 1 Saturday.
Offline Greg H
  • When two cams is one too many .
  • Still crazy after all these years .
« Reply #38 on: December 29, 2012, 02:59:06 PM »
Hello and welcome Sara  :) . Lovin the build so far, particularly like the fuel tank , thats what I call "functional " ;).
« Reply #39 on: December 29, 2012, 05:15:15 PM »
What Brembos? Those big ole rotors are the issue. I use F05's with original rotors and had to fool a long time to make them work.
Offline Sara
« Reply #40 on: December 29, 2012, 10:34:31 PM »
Hm mm no, no help for me.  :( But that's the way that i like it.
Poor Sara, al alone in her garage  :)
Offline Sara
« Reply #41 on: December 29, 2012, 10:42:15 PM »
Yeah, very functional indeed.  :) Very first attempt in building a fuel tank myself. Welded with easyweld or should i say soldered?
There probably will be an "evolution" in tank form in the future. Maybe a bit more elegant. ;)
Sara
Offline Sara
« Reply #42 on: December 29, 2012, 10:56:56 PM »
The rotors are from a Yamaha and the discs are custom made for me, they are only half the width of the originals and much lighter. I have 1 cm between the discs and the forklegs, on each side.
Could you measure the overall width of a F05 caliper? Mine are F08, but not very sure.
Thank you
Sara
« Reply #43 on: December 30, 2012, 03:56:05 AM »
Yes those are 08's. Sorry I'm away from where my bike is for awhile and can't find a picture or measure the modified caliper. Basically removed material from the backside at the same angle as the spokes to clear. I just can't say for sure you can remove enough from the 08's but I think maybe Voxonda (Rob) has.
Offline Sara
« Reply #44 on: December 30, 2012, 04:52:53 AM »
Thanks for the reply, but i think that the best solution is to obtain some F05's. Going to contact some people who might help me or point me in the right direction. ;)
Thank you
Sara
« Reply #45 on: December 30, 2012, 05:35:33 AM »
They are smaller and lots of braking power. I use a 12mm Brembo master and it's a good combination.
Offline Sara
« Reply #46 on: January 06, 2013, 10:06:07 AM »
Fitted the wheels with tires and already it looks like a motorbike.
Sara
Offline Sara
« Reply #47 on: January 06, 2013, 10:10:51 AM »
My "quest" for the brembo's F05 hasn't had much result yet. ( holidays) But i found a very nice looking oilcooler (for free) and another seat ( also for free). Too bad it is 5 cm to wide, looks very comfy.
Sara
Offline Sara
« Reply #48 on: January 20, 2013, 09:53:17 AM »
Last sunday my neighbour came to my garage to chitchat about bikes. Nice tires , he said, like the profile but is the rear tyre not mounted backwarts? What do you know about bikes, of course the tyre is not mounted backwarts. ::) Look at the arrow on the tyre.  :o Ouch. Humble pie. I made a beginners mistake and mounted the rear tyre wrong way around. What was i thinking. :(
Thank god for neighbours. :)
Sara
Offline Sara
« Reply #49 on: January 24, 2013, 09:44:39 AM »
Had some spare time today and mounted the carbs and the oilcooler. And reversed the rear tyre ;). Lined up the chain to.
Sara
