Author Topic: 1975 CB750 K5 SPYDER  (Read 63678 times)
Offline goldarrow
  • one day, i'll be an
Re: 1975 CB750 K5 SPYDER - Moving on FORWARD
« Reply #150 on: September 07, 2013, 08:41:52 PM »
Oh, that one.  Truly custom.
The bolts for your foot pegs need to be that long?
6" would have been perfect, but I got 5.5"
CB550 K0
« Reply #151 on: September 07, 2013, 08:53:28 PM »
Just installed em on my K5 last week and they were 2".
Offline goldarrow
« Reply #152 on: September 07, 2013, 09:01:29 PM »
Interesting.  Stock pipes? Pipes holes are already about about 1.5" each, I frame hole another may be 1", foot peg, I also used lock washer and flat washer, and the nut may be 3/4" thick
CB550 K0
« Reply #153 on: September 07, 2013, 09:05:32 PM »
No, that's the difference.  I mounted the Hookers.....
Offline goldarrow
« Reply #154 on: September 09, 2013, 12:37:18 PM »
Got the right side pipes mounted.
Then tried to start up the bike, but had the hardest time of my life to get it to start :( pulled the plugs, wet from fuel.  Cleaned and gapped, bike started but not idle.  Tinker with petcock, looked fine.  Dropped the jets, looked fine not clogged, some sediments in the fuel bowl. Fuel bowls were low in gas.  Hmmm.....fuel not flowing to carbs, hmm....  Blow fuel line with mouth, no flow, hmm...  Perhaps carbs passages are clogged up??? I guess, Time to pull the carbs again...
CB550 K0
Offline MoMo
  • Ride like you're invisible
« Reply #155 on: September 09, 2013, 04:13:49 PM »
Seems as though you are getting fuel, make sure the spark advance unit is working...Larry
Offline lucky
Re: 750 K5 SPYDER reincarnation has begun!
« Reply #156 on: September 09, 2013, 04:22:07 PM »
Cleaning up the pistons and rings, getting ready to put back,
but of course something has to go wrong.  Soaked the pistons and rings in soapy water simple green mix, at least one ring still broke upon removal. Carbon and crude were that much in the groves and oil holes, took me a while to poke through 18 holes each piston, then soda blasted away to finish up the cleaning
Ordered new set of rings from Japan, one piston pin was badly pitted, too much soaking, ordered a new one from Honda.
It does not matter if the old rings break. You cannot re use them.
Just in case I will say it. NEVER use a wire brush on the piston or its finished.
« Last Edit: September 09, 2013, 04:24:06 PM by lucky »
Offline goldarrow
« Reply #157 on: September 11, 2013, 06:35:46 AM »
Found my issues.  Float valves seemed very sticky to the seat on all 4,  took out all brass pieces and clean them again one more time.  Anyone have a good recommendation for starting point for jetting?
K5 stock motor on
7a carbs
Float 26mm
Main 120 stock, but i have 130
Slow 40
3rd grove
1 turn out
Needle 27201
Air intake UNI individual pod filters, HM300 exhaust pipes no baffles
I'm thinking I might be lean to begin with but not sure where to start the jetting changes.
CB550 K0
« Reply #158 on: September 11, 2013, 07:35:17 AM »
Start there but why no baffles?
Offline goldarrow
« Reply #159 on: September 11, 2013, 08:12:28 AM »
Pipes didn't come with Diffuser and they are pricey on feebay
http://item.mobileweb.ebay.com/viewitem?sbk=1&nav=SEARCH&itemId=321090624823
CB550 K0
« Reply #160 on: September 11, 2013, 08:42:16 AM »
Because they sound like a motorcycle with the baffle ends out..
Offline goldarrow
« Reply #161 on: September 11, 2013, 11:54:07 AM »
Let's hear it.
http://youtu.be/Z5HWeK5ZWVo
Videos after put all carb pieces back together.  Started right up! But with so much hanging idle that won't come down
« Last Edit: November 13, 2013, 10:31:32 AM by goldarrow »
CB550 K0
Offline goldarrow
« Reply #163 on: September 11, 2013, 04:27:46 PM »
Wonder if the 341 baffles could be made to fit?
http://www.ebay.com/itm/Honda-CB-750-CB750-K2-K5-exhaust-diffuser-baffle-OEM/141014856608?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D
Possibly, but gonna first try to see if I can work with jetting and have my bike sounds like a motorcycle :)
It actually sounded nice when the idle hung around 3k rpm, then quickly shut down the bike with kill switch
CB550 K0
« Reply #164 on: September 11, 2013, 04:54:46 PM »
Oh, I bet it sounded awesome, my ol Black Bueti had open exhaust. But, can be hard to tune, but you're a pro, so I'm sure you'll get it there.
Get it warmed up and set that idle around 1200.
Offline goldarrow
« Reply #165 on: September 12, 2013, 01:13:04 PM »
Replaced carbs return spring.
The top spring is off the carbs on the bike, bottom spring from parts carbs.
Most hanging idle is gone, just a bit left.
I think the problem may also be that I'm using single cable throttle on push/pull 2 throttle cables carbs, or just simply old cable.
Engine got hot pretty fast so I went ahead and did carb sync, just because I'm already there
And here's another vid, with a bit of hanging idle
http://i1061.photobucket.com/albums/t467/goldarrow/133F9A16-EC38-429D-B572-639005DBFBC3-3619-000001637D58E1FC_zps9dbf2a90.mp4
CB550 K0
« Reply #166 on: September 12, 2013, 05:46:36 PM »
Sounds good, like a real motorcycle.  Highly doubt hanging idle is lack of push cable, get a new puller.
Test ride?
Offline goldarrow
« Reply #167 on: September 13, 2013, 09:18:23 PM »
Working on the bike a little but today. Redo front brake, removed right side caliper and hose, filled brake fluid and bled.  Rock the bike back and forth, great.  Then looked down to the left to kick the kickstand up, puddle of oil by kickstand! >:( and I had already replaced the shifter seal few months ago with Honda seal.         >:(
Wiped off the oil, and realized I forgot to snap picture, but I'm sure there will be some more in the morning
CB550 K0
Offline goldarrow
« Reply #168 on: September 15, 2013, 07:31:49 PM »
Oil leak around case seam by the bolt near sprocket corner. Tighten up the bolt, and hopefully this hold off the leak for a while as I'm not mentally ready to do bottom engine tranny tear down.
Bike is ready for test run to gas station.  Will see how it goes tomorrow.
CB550 K0
Offline goldarrow
« Reply #169 on: September 17, 2013, 11:30:02 AM »
Pulled my bike out to see the new world, parked next to the sisters
Got it to start, but no go! :(. Pulled clutch, put in gear, release clutch, lost power :(.  Pipes on 3 and 4 were little colder than the other two, so I swapped out with a new one.  No change.  Lost power after put in gear and release the clutch.
Mad.  Then parked the bike, and took the green 550 out for a ride.
« Last Edit: September 17, 2013, 06:23:55 PM by goldarrow »
CB550 K0
« Reply #170 on: September 17, 2013, 06:17:06 PM »
Not running on all four.  Nice pic, BTW.
Offline goldarrow
« Reply #171 on: September 17, 2013, 06:21:35 PM »
Just realized that I've used up 10gb bandwidth on photobucket
CB550 K0
Offline goldarrow
« Reply #172 on: September 17, 2013, 07:39:28 PM »
The bandwidth will reset on 25th of the month.  Let's see if I can live with it.
CB550 K0
« Reply #173 on: September 17, 2013, 08:01:42 PM »
Must be all the pictures of the kids!
Offline goldarrow
« Reply #174 on: September 17, 2013, 08:06:10 PM »
they love to be around their bikes, that's for sure  ;) ;)
CB550 K0
