Author Topic: Wheel bearing removal  (Read 697 times)
Offline Big_e78
« on: November 10, 2012, 06:57:50 AM »
I've tried a drift, heat and penetrating oil but still can't drive these bearings out. I did remove the retainer and I'm trying to drive each side "out" by catching the tiny lip of the bearing with a drift.  Any tips I haven't tried? Could I even get a puller between the inner spacer and the bearing?
Offline CycleRanger
  • No comment about being an
Re: Wheel bearing removal
« Reply #1 on: November 10, 2012, 07:03:50 AM »
You'll need to use a bit of force to push the spacer over to the side a bit so you can get a bite on the inner race and drive them out. I usually use a big screw driver.
Or use a blind bearing puller.
Either way you have to force the spacer out of the way.
Offline Big_e78
« Reply #2 on: November 10, 2012, 07:08:56 AM »
Just use your hand to cock the screwdriver to the side or do I need to apply more than hand pressure?
Offline CycleRanger
« Reply #3 on: November 10, 2012, 07:15:47 AM »
Depends on how strong you are and how big a screwdriver you use.  ;)
You may have to give it a whack.
You'll bend the tabs on the spacer but that's ok, you can bend them back before you reinstall.
« Reply #4 on: November 10, 2012, 07:20:47 AM »
I had the same problem till I read the posts on here. That retainer need to be bent down so you can get good contact with the side of the bearing. Mildly heating the hub around the bearing can make the aluminum expand a bit before the steel does. Get a good piece of the bearing edge exposed and give it some good whacks in a circular pattern and it will come out. Take your new bearings and shove them in the freezer now so they freeze down good. They will almost drop in place. Tap them down with the old bearing.
Offline wvshooter
« Reply #5 on: November 10, 2012, 07:23:59 AM »
I'm not saying it's time to try this but this is something I've done when I can't get a good catch with a drift punch. Use a Dremel with a cut off wheel small enough to fit inside the bearing's inner race. Grind a notch that the drift punch can catch onto. I've done this as a last resort when nothing else works.
Offline Big_e78
« Reply #6 on: November 10, 2012, 07:25:19 AM »
Thanks for the tips. I'll give her a go.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #7 on: November 10, 2012, 07:25:19 AM »
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #8 on: November 10, 2012, 08:37:04 AM »
once you get the spacer shifted, hit the isht out your drift on one side of the bearing, and the repeat on the opposite side. repeat. itll come out.
watch the knuckles   ;)
Offline ncstatecamp
« Reply #9 on: November 11, 2012, 08:34:46 PM »
Front or rear?
Offline Big_e78
« Reply #10 on: November 12, 2012, 03:46:32 AM »
My question was in regards to the front. I used the smack the spacer move successfully. Thanks
Offline Big_e78
« Reply #11 on: November 12, 2012, 04:45:49 PM »
On a side note, had problems shifting the spacer on the rear. Went to autozone, they loaned me a blind hole bearing puller. Super easy with that.
