Author Topic: Setting timing on CB550-Static or Advance/dynamic timing?  (Read 13813 times)
Re: Setting timing on CB550-Static or Advance/dynamic timing?
« Reply #25 on: November 15, 2012, 06:53:51 PM »
Lisa, start the bike up, and verify both the 1-4 and 2-3 F marks are aligned at idle with the strobe. Next, gradually increase the RPM until the advance stops moving. Ideally, the pointer will be lined up between the advance marks, equal between 1-4/2-3, and occur around 2500 RPM. If full advance occurs lower than that, the advance springs may be stretched. This would also apply if there is a significant change noted between static, and dynamic testing at idle.
Offline Mooshie
« Reply #26 on: November 15, 2012, 07:11:38 PM »
Thank you Scott.  I think my question opened a can of worms  ;) haha
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
« Reply #27 on: November 15, 2012, 07:27:42 PM »
You're welcome. BTW, the use of a strobe as a tool as I've described applies to point, hybrid (such as the HM system) and fully electronic systems.
