Rebel, I'm just a backyard mechanic so I called my local Honda shop for a mechanic's opinion. He says, "if the motor is torn down, go with the endless one, if not use the one with the master link, it should be okay unless you're going to be racing the bike. Regular riding and it will be fine." So, there you have it. One bit of advice, stuff a bit of a rag down the cam chain tunnels, before installing the link, you wouldn't want to drop the clip down there as crazypj points out. And make sure the open end of the clip is pointed in the right direction. I believe that's away from the direction of travel. Someone will confirm that I'm sure.
Crazypj, thanks for the tip about the DOHC cam chain. I've read where the tensioner next to number 3 exhaust is easily stripped. Cliff.
