Author Topic: CB 100 Tinker Toy  (Read 9051 times)
Offline WhyNot2
  • I'm finally an
Re: CB 100 Tinker Toy
« Reply #25 on: June 21, 2015, 03:41:46 PM »
DID is good for the chain.  If the sprockets aren't cupped or elongated chain only  replacement will suffice.
I don't have a front sprocket at all, was missing when I bought this little thing.
I have a few rear sprockets. No chain.
I purchased an RK Standard 428 chain w/ the red box off ebay for $20 incl. shipping.
I'll do a search on ebay.
Thanks for the input guys.
Offline grcamna2
« Reply #26 on: June 21, 2015, 04:14:16 PM »
I have a little CB125S and it takes a 15 tooth fr. sprocket;your little CB100 takes a 14 tooth fr.
The oem Honda front countershaft sprocket is much beefier & harder steel than a JT or other China-sprocket & will last you at least twice as long;it's well worth the extra small change they want for it..
Offline WhyNot2
  • I'm finally an
« Reply #27 on: June 21, 2015, 04:39:53 PM »
I try to stay OEM on stuff like this, was just trying to get an ideal what others have done with these little things.
Thanks for the info.
Offline grcamna2
« Reply #28 on: June 21, 2015, 05:51:25 PM »
I hear you,I love my little Honda  ;D and to me it's a 'Do-All-Anytime gas mileage champ'. I can very easily fit it into my life  :) I'll be moving soon and want to sell my other 2 and keep it for one reason is because it's so small and will fit inside a smaller size trailer along w/ my other stuff. Did you ever get your engine rebuild finished ?
Offline MoMo
  • Ride like you're invisible
« Reply #29 on: June 21, 2015, 06:50:06 PM »
[/quote]
You are moving again Bill ??? ???...Larry  sorry for the thread hijack
Offline grcamna2
« Reply #30 on: June 21, 2015, 07:19:50 PM »
[/quote]
Yeah Larry,I thinking long range toward the end of the yr.;nothing final yet..  End of thread-jack
Offline WhyNot2
  • I'm finally an
« Reply #31 on: June 21, 2015, 07:37:35 PM »
Got the engine rebuilt to the best of my knowledge.
Hasn't been started yet, just put back together.
Lost that stupid spring to the carb, so just decided to order another from ebay.
Still need a battery, and play with the electrical connectors to ensure I'm getting juice.
Will it be ok to fire up the engine without the sprocket and chain?
Offline MoMo
« Reply #32 on: June 21, 2015, 07:52:54 PM »
sure thing, no problem...........return of thread...Larry
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #33 on: June 23, 2015, 07:28:19 AM »
Whoa - that was from a vinegar soak?!? How long did you leave it in there?
Offline WhyNot2
  • I'm finally an
« Reply #34 on: June 23, 2015, 09:35:36 AM »
Ahhh, probably a week or so ::).....or longer ???...............possibly a few............ :o
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #35 on: June 24, 2015, 09:03:35 AM »
Haha yeah that'll probably do it. I soaked my CB1000C carbs in Pine Sol as recommended on the DOHC forum.. left 'em in there for ~48 hours and it ate some of the plating off steel components. I guess the trick is to check it every 12 hours or so.
Offline WhyNot2
  • I'm finally an
« Reply #36 on: June 24, 2015, 09:45:27 AM »
That spring was real skinny from the get go.So I figure it's gone.
Offline WhyNot2
  • I'm finally an
« Reply #37 on: June 27, 2015, 06:01:42 AM »
Well, parts on hand, will install today, hopefully, unless the wife hands me a list.
Maybe fire this little thing up for the first time in 20 or so years.
Offline grcamna2
« Reply #38 on: June 27, 2015, 08:05:02 AM »
All right  8)
Offline WhyNot2
  • I'm finally an
« Reply #39 on: June 27, 2015, 04:04:03 PM »
Got that list plus, still over 100 degrees in the garage..........................
Maybe 2morrow.
Or sometime during the week.
I'm off for 4th of July shut down week, and wife has to work............let the build continue.........!!!!
Offline WhyNot2
  • I'm finally an
Offline grcamna2
« Reply #41 on: June 27, 2015, 04:38:05 PM »
Did you need to do any work on your fuel tank inside? my tank has lot's of rust and needs more work.I've done the vinegar clean a few times but it's getting thin so I may have to coat it. ever tried Red-Kote ?
Offline WhyNot2
  • I'm finally an
« Reply #42 on: June 27, 2015, 04:56:47 PM »
Oh yeah, forgot to post that.....................................:
The tank on the bike was toast, and I mean swiss cheese toast.
So I bought another, and found it really rusted inside after it got here.
I did give the tank the vinegar treatment and noticed little pin holes on the bottom.
Ended with this.
Now I don't know what to do.............................................
Offline MoMo
« Reply #43 on: June 27, 2015, 05:34:04 PM »
looks like you are in the market for another tank :(
Offline WhyNot2
  • I'm finally an
« Reply #44 on: June 28, 2015, 02:10:16 AM »
Yes I am....................any leads? :D
Oh yeah, looking for a seat, or seat pan at least, and a headlight.
« Last Edit: June 28, 2015, 02:12:35 AM by budlite282 »
Offline MoMo
« Reply #45 on: June 28, 2015, 05:20:49 AM »
Saw a new Asian repro for170 plus shipping.  Try starting it with a remote tank...Larry
Offline WhyNot2
  • I'm finally an
« Reply #46 on: June 28, 2015, 05:28:35 AM »
Yea, think I seen that too, not really sure I want to do that. May be my only alternative though, I still have time for that anyways.
I also have a small tank I will use to start it. Still in need of a front sprocket and chain, so won't be able to ride it, just want to hear it run.
It sat leaning on a guys barn for about 15 to 20 years.
Heck, the barn was falling down around it.
Offline WhyNot2
  • I'm finally an
« Reply #47 on: July 01, 2015, 07:49:08 AM »
wooooooohooooooooo..........
It started.........................wow..............unbelievable.
I actually tore an engine down replace the piston rings and bored the cylinder .050mm over spec.
And it ran.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #48 on: July 01, 2015, 10:41:04 AM »
I have a CB125 that I restored. I couldn't stop grinning when I fired it up ;D. A huge departure from the sohcs.
Nice job. It's now to enjoy. :)
Kawi GPz900, H1
Offline WhyNot2
  • I'm finally an
« Reply #49 on: July 01, 2015, 11:09:59 AM »
Hey thanks Killer.
Rejoice was short lived.........the kicker stripped on the shaft.....arrrrrggggggggghhhhh...!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fvvvvvvvvvvvvvvvvvvcccccccccccccccccccccccckkkkkkkkkkkkkkkkkkkkk......................!!!!!!!!!!!!!!!!!!!!!!!!!!!
Scrap pile I guess/.
