Author Topic: CB 100 Tinker Toy  (Read 9109 times)
Offline MoMo
  • Ride like you're invisible
Re: CB 100 Tinker Toy
« Reply #75 on: July 19, 2015, 04:28:55 PM »
only 3 things to check, spark at the right time, fuel in the correct mixture and good compression...Larry
Offline Killer Canary
  • Typical Bran Muffin
Kawi GPz900, H1
Offline WhyNot2
  • I'm finally an
« Reply #77 on: July 19, 2015, 06:27:52 PM »
Thanks MoMo......compression I was told can't be checked until the thing runs long enough to seat the rings.
It ran real well, when I first fired it. But wouldn't idle on it's own.
Since then, I've played with the carb settings, and got it to idle on it's own, then started pizzing gas out the over flow.
Pulled the carb apart, doesn't pee no more, but won't run at all now.
Pulled plug, blackened sooty. Cleaned plug, got spark at the point, barely runs.
Crap...........crap.
« Reply #78 on: July 21, 2015, 01:44:48 PM »
clear tube test your fuel level, and adjust the float to get the fuel level spot on.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #79 on: July 21, 2015, 02:38:54 PM »
^I was thinking the same thing.
Also, FWIW, LED bulbs in a 6v system isn't necessarily a good idea. For instance, use 'em in your turn signals and you'll find that they don't blink any more. This is because the regular 6v bulbs act as a load on the system, allowing the mechanical winker to wink. It's all a matter of balance.
« Reply #80 on: July 21, 2015, 02:49:53 PM »
Just thought I'd mention that if you're having trouble finding 6v INSTRUMENT bulbs
Kawi GPz900, H1
Offline WhyNot2
  • I'm finally an
« Reply #81 on: July 21, 2015, 05:29:01 PM »
Thanks guys, appreciate the responses.......119 degrees in the garage has forced me into the house and a/c.
almost too hot to go out there to the frig to get a beer.
