Author Topic: cb750k4 how to plug up the chain oiler!??!  (Read 13389 times)
ccmclane
Re: cb750k4 how to plug up the chain oiler!??!
« Reply #25 on: November 20, 2012, 09:01:39 AM »
754 - I am interested in buying one from you if you make extras.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #26 on: November 20, 2012, 09:09:00 AM »
Same here as long as it does not dent a wallet as bad as the Yamiya part.
Offline WhyNot2
  • I'm finally an
« Reply #27 on: November 20, 2012, 01:20:58 PM »
I'm in too.
Offline Garystratos201
  • I have never been a
« Reply #28 on: January 02, 2013, 01:51:53 PM »
I know this post is a couple of months old but in case you have made some I`m in also.......Gary
Visit my build project;
http://forums.sohc4.net/index.php?topic=111620.0
Current ride; Bass boat.... 2005 Ranger 521VX,250 hp Mercury Verado, super charged and direct fuel injected. Not a bass on the lake can out run me !!!
Offline Cqyqte
« Reply #29 on: January 02, 2013, 02:09:46 PM »
This is what I did:
Cut a flat round rubber plug then an aluminum slug with an O ring, the center screw rams the solid rubber plug up against the end hole, the O ring seals the shaft.
Offline el pachuco
« Reply #30 on: April 25, 2016, 09:33:31 PM »
Got a new 17Tooth sprocket coming this week so I reckon I get to see what this is all about.
Can't be that hard to plug a hole............LOL
JWExperience
« Reply #31 on: April 25, 2016, 10:13:30 PM »
I have one of the joker plugs I'm not using, I could ship it for a couple bucks to cover gas to the post and shipping or something. Pm me if anyone wants it.
« Reply #32 on: May 15, 2022, 03:56:26 PM »
Is anyone taking over for Frank on these oiler cap off plugs? I a couple as I need to cap my K4 and K5 chain oilers. My K5 the seal(or is it an o-ring?) is gone, split apart and drenching the motor and kick stand/center stand/swingarm.
Thankfully my K6 doesn't have the oiler.
« Reply #33 on: May 15, 2022, 06:54:40 PM »
My failed seal on the chain oiler........
Offline chiefum
« Reply #34 on: May 15, 2022, 07:25:11 PM »
Last time I talked to Frank about it, sounded like he was all set, not sure if he had made any more. He was getting me a shipping cost, then I forgot to ask him about it before he passed. I would be interested in one, if anybody else makes his design.
Offline Alan F.
« Reply #35 on: May 15, 2022, 07:30:22 PM »
I've got a chainsaw spark plug that I was planning to use on my K3 if necessary, it'll fit under the cover & everything.
Offline pjandrew99
« Reply #36 on: May 16, 2022, 11:11:24 AM »
Below is the question I asked awhile ago and never got a response. I went ahead and made the plug. It fit fine but opted to give the chain oiler another shot making sure it was screwed in all the way. I'll move to this if it still leaks.
May go the spark plug route to plug the chain oiler. Would a plug similar to the B5ES do the trick?
Thanks!
14mm x 1.25
19mm Reach
21mm Hex
Current Projects
Honda CB750K1
Yamaha SR250
Honda SL350 K0
« Reply #37 on: May 16, 2022, 03:19:20 PM »
So you didn't lop off the ceramic end and fill it?
« Reply #38 on: May 16, 2022, 03:25:52 PM »
What plug did you use Alan?
Offline Alan F.
« Reply #39 on: May 16, 2022, 04:54:59 PM »
« Reply #40 on: May 16, 2022, 05:34:17 PM »
Offline Alan F.
« Reply #41 on: May 16, 2022, 10:46:54 PM »
Thanks
« Reply #42 on: May 16, 2022, 10:54:49 PM »
The threaded portion of that spark plug is too short to cover the hole in the side of the counter-shaft. There are more recent threads regarding chain oiler plugs. I made a one-off plug for my K1, which was missing the rubber seal altogether.
« Reply #43 on: May 16, 2022, 10:55:05 PM »
Thanks!
14mm x 1.25
19mm Reach
21mm Hex
So you get a response this time...... I don't know if it would be necessary or not to go deep or just seal the end of a short spark plug and threads(how much pressure does that oil feed have?)
« Reply #44 on: May 16, 2022, 11:00:10 PM »
I guess I missed those more resent threads. I'm a carpenter not a machinist..... I like that plug.
« Reply #45 on: May 16, 2022, 11:00:28 PM »
There is zero pressure: the oiler is fed from the oil/air separator drain in the oil tank, which is somewhat inconsistent, depending mostly on engine RPM.
« Reply #46 on: May 16, 2022, 11:36:25 PM »
OK. Thanks. I think I remember reading there wasn't pressure a couple days ago when I was reading through some threads on the oiler.
So then, does your plug screw in to bottom out/seal off the oil hole then? Did you use a thread locker to seal the threads and lock the plug from backing out?
I just saw a thread in which Frank posted a picture of his plugs. I wonder if any were left in the sale of his estate sale?
« Reply #47 on: May 16, 2022, 11:51:52 PM »
So is there a feed hose from the tank directly to the oiler then? The reason I ask is pieces of the puzzle in my remembering threads and conversations coming together, and I was over at Anders shop last October, talking with him about getting one of his high output alternators and he mentioned the K6 oil tank was different than the K5 and earlier tanks and was a good thing to use with his setup for clearance of mounting the R1 regulator/rectifier.
I know on the K6 Honda eliminated the chain oiler(double checked the K6 bike I have and remember that from the time in the parts room learning the 750s in the 70s. Not all is forgotten yet......
« Reply #48 on: May 17, 2022, 01:12:09 AM »
Well another sleepless night.... There seems not to be a hose from the tank as I surmised but there is a tray in the case that collects the oil to deliver the oil to the oiler. Still learning at 65....
Offline Alan F.
« Reply #49 on: May 17, 2022, 05:57:51 AM »
Ah, I didn't realize there was a hole in the side of the countershaft for this oil flow, thank you Scottly.
