Thanks,
leetmeatcr and
rtbmrgl. Exciting and fun is what's it's all about, right?
As for common seals and other bits and things, I've tried not to stray too far from buying Honda. Partzilla.com has been my go-to lately.
I'm relying that my carbs, according to the PO, are in OK condition so I've done my due diligence in cleaning them as best I can. So as the carb saga continues, my next purchase for these things is to replace the spring clips for the hoses:
95002-02070 CLIP, TUBE (B7)95002-02100 CLIP, TUBE (B10)I realize these don't necessarily have to be the Honda ones so I'm stopping into my local Napa Auto Parts to see if they might have something comparable.
Also thinking to go with the
Uni Pod Kit. Hope it fits and works. Any other recommends out there? I like the look of the
K&N pods I can't reason with the cost.
Good going using Honda carb kit, I used a cheap aftermarket when I rebuilt the carbs on my 500, within a month the o-rings began deteriorating. I removed one of the bowls, had a plugged pilot jet and noticed the o-rings in bad shape. They cost more, but well worth it.
