Author Topic: sci cb550f tires 3.50 front and rear????????  (Read 1151 times)
Offline mario medeiros
« on: February 02, 2014, 12:39:22 pm »
Thinking of buying sci duro tires and their ad says 3.50 is bigger than the stock 3.25 but it will work well,only thing it does not say is the 550 uses a 4.00 on the back.I don't mind a skinner rear but just wanted to make sure a 3.50 will fit my rim.Thanks
Re: sci cb550f tires 3.50 front and rear????????
« Reply #1 on: February 03, 2014, 07:05:18 am »
The rim outside rim is 2 3/4 wide any idea on tire sizes for a rim that wide?
Offline jonda500
« Reply #2 on: February 03, 2014, 09:29:08 pm »
I'm pretty sure it'll fit the rim but it may rub against the front mudguard. Back in the late 80's when tyres here still had sizes in inches, I always used to run 3.5 front 4.0 rear tyres on my cb400-4.
A starter clutch thread:
Offline Deltarider
  • First round...
« Reply #3 on: February 04, 2014, 12:07:41 am »
When I bought my CB500 secondhand in 1980, it had a 3.50 tyre front (Conti RB2) and a 4.00 (K112) rear, both on standard rims. Although the front tyre did not rub, the next time I needed a new one I went to 3.25 as I fail to see what the advantage of a wider tyre is. Since 3.75 was not available, I've always stayed with 4.00 rear tyres. No problem at all. The standard rear rim can have a 3.50 or a 3.75 or a 4.00 tyre no problem.
« Last Edit: February 04, 2014, 12:34:26 am by Deltarider »
CB500K2-ED Excel black
« Reply #4 on: February 04, 2014, 04:48:23 am »
Thanks I have a 3.00 on the front (too skinny) and a 4.00 on the rear (too wide) seeing as both rims are the same size I want to run a 3.50 on both,just because I like the look,no other reson.Mario
Offline Deltarider
  • First round...
« Reply #5 on: February 04, 2014, 07:19:42 am »
I see. Anyway standard rim size front is 1.85 and rear 2.15.
« Reply #6 on: February 04, 2014, 09:01:42 am »
My rims on the outside are 2 3/4 of a inch front and back?
Offline becken
1976 CB550F bought new
1981 CM400A wife bought new
2004 GL1800
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: February 05, 2014, 05:10:51 am »
rim size is measured on the inner spacing.  Also, your rims should be stamped with the standard sizes that deltarider  said in his post...Larry
