Author Topic: 1978 CB550 Twin front discs  (Read 2836 times)
Offline JD
  • Dont let the bastards grind you down.
« on: November 22, 2012, 06:18:00 AM »
Im wanting to fit another brake disk to my front wheel, how easy is this to do and whats required?
Re: 1978 CB550 Twin front discs
« Reply #1 on: November 22, 2012, 06:44:53 AM »
As you are in scotland try visiting the UK site, http://www.sohc.co.uk/index.php
 register with the same user name and PM me with your direct email address. I will send you a word document
Offline Scott S
« Reply #2 on: November 22, 2012, 11:55:05 AM »
 It can be done. I got a speedo drive ring from a member here (check the classifieds, or search for DDC....Dual Disc Conversion).
 It requires a couple of holes to be drilloed and tapped to mount it. Some people file down a stock speedo drive on certain models.
 You'll need another caliper and rotor, of course, as well as a brake hose and I used a double banjo bolt.
 It takes some fiddling with the RH caliper mount. There's nothing to do but fit, re-fit and fit some more until you get it to float correctly and center properly. Sorry, there's no easy way out here. I had to grind a little off the mounting pad and play with some spacers.
 I tried a few different master cylinders seeking the lever feel I like. I ended up with an aftermarket M/C, but some people use stock or a GL1000 M/C. The BIGGEST difference in lever feel and stopping power came from adding EBC brake pads.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline JD
« Reply #3 on: November 24, 2012, 12:55:04 PM »
Thank's Scott thats exactly what i needed to know..... what discs have you used? or are they stock discs drilled?
Offline Scott S
« Reply #4 on: November 24, 2012, 01:31:41 PM »
 Stock discs drilled, also by a member here. Look in the "services offered" section of the classifieds.
'71 CB500 K0
'81 Yamaha XS650
