Support the site. Your contributions keep this site running.
The new shock mount to accomodate the wider F swing arm. I used 3/4" 8 Grade bolt to make it, it still needs a washer beefore I weld it in.
Replacing cam chain, ugh.
Sorry, JB, I took a break.
Quote from: 70CB750 on May 04, 2018, 04:54:22 amSorry, JB, I took a break.Hope you've been well, 70CB. Your presence has been sorely missed.
Beautiful guide wheels Prokop, good to see you back and doing well...Larry
Are you dropping in on the machinist forum ? I JOINED UP OVER there..
Red got a new sprockets and chain. 17/48. Planed to get an o-ring but X - ring was all the local Honda had; X-ring it is.The old chain was just a regular one I got to used up what life was left in sprockets that came with F2 parts. It stretched unevenly and you could feel it on acceleration, time to upgrade.
Added navigation.
I routed bowl air lines together. Eventually will add a nipple to the air box.
Quote from: 70CB750 on December 31, 2018, 06:54:29 amI routed bowl air lines together. Eventually will add a nipple to the air box.please explain why
