Author Topic: Removing intake rubber?  (Read 684 times)
Offline stereosilence
  • 1975 CB550K
« on: November 27, 2012, 02:52:48 PM »
Hi, my crap is going to the soda blaster this week and I can't get the rubber intake tubing off the manifold (in absence of the technical term, it goes between the carbs and the ports).
Is there a trick? Do I cut it off and buy new ones?
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Removing intake rubber?
« Reply #1 on: November 27, 2012, 03:34:00 PM »
Heat 'em up with a hair dryer.
Offline slyguy
« Reply #2 on: November 27, 2012, 03:54:26 PM »
I gotta do mine too, then soak or boil with the wintergreen oil mix..which I still need to get...
  • 1975 CB550K
« Reply #3 on: November 27, 2012, 06:43:46 PM »
After you get them off you put wintergreen oil mix? What is that stuff anyway?
