Author Topic: Removing swingarm bushings?  (Read 16089 times)
Offline stereosilence
  • 1975 CB550K
« on: November 27, 2012, 02:56:55 PM »
I removed the bolt from my swingarm and I think I have the dust cap and possibly pivot off.
How to I get the bushing out?
Re: Removing swingarm bushings?
« Reply #1 on: November 27, 2012, 04:37:22 PM »
Many folks use a hacksaw blade or a triangular file to cut through the bushings then carefully chisel them out.
Yes its not uncommon to have to go "medieval" on them.  Carefully.   ;)
Offline Kwality
« Reply #2 on: November 27, 2012, 04:49:03 PM »
Yep +1 on the hacksaw blade.  That's what I did, anyway.  Two cuts on each bushing, then tap out from the other side.
Offline Bailgang
  • Scott
  • Indiana
« Reply #3 on: November 27, 2012, 05:33:49 PM »
The hack saw blade and chisel technique does work but as MCRider said, the key word is "carefully".
Or you can rent a blind hole bearing puller from a local auto parts store and have both of them out in 2 or 3 minutes. Not all auto parts stores have them in stock though.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
« Reply #4 on: November 27, 2012, 06:07:01 PM »
Carefully = don't scar or dig into the area where teh new bearing will be going. If you do you can always dress it down, but best to avoid.
Offline timbalish
« Reply #5 on: November 27, 2012, 06:13:45 PM »
For mine, I used a metal rod that I originally got for adjusting my garage door coil springs (18" x 1/2" metal rod )and used a hammer and whacked them out, tapping all around the bushing.  The rod was small enough to be able to angle to hit the back of the of the inside of the bushing. The second was easier because you could hit it straight on after the first bushing was out.
1977 CB750k
  • 1975 CB550K
« Reply #6 on: November 27, 2012, 06:44:58 PM »
Ok. Thanks guys. I would *like* to not have to destroy them. Apparently replacements are stupid expensive ($50?).
« Reply #7 on: November 28, 2012, 05:57:14 AM »
You can't really remove them without destroying them. :(
Yup, gotta destroy them.
The expense is directly related to the importance of their purpose.
« Reply #8 on: November 28, 2012, 06:00:50 AM »
If they're 35+ years old, it's time to replace anyway.
  • 1975 CB550K
« Reply #9 on: November 28, 2012, 09:10:22 AM »
Is there a preferred place to get them from? Someone around here that machines them possibly?
Offline iron_worker
« Reply #10 on: November 28, 2012, 11:21:35 AM »
Check out the tool I created to do the job. (ignore the long bolts ... they were used to press the lower shock bushings out... also handy.) They are the three washers you see on the bottom right. I cut flats down on each side so they can slide through the bushings and then be turned 90degrees once inside. The round edges will then seat on the back of the bushing. This allows you to then come in with a socket and extension or a large rod/drift and get a better purchase on the back side of it.
I tried the hacksaw method but mine were so frozen in that that didn't even work. I just used a hacksaw, a file, and a couple hours of patience to make these bearings "drivers". I made 3 so I could stack them up and get a bit more rigidity. I didn't want them folding up and going through the bushing.
Anyway, hopefully that makes sense.
IW
Offline CycleRanger
  • No comment about being an
« Reply #11 on: November 28, 2012, 05:48:08 PM »
« Reply #12 on: November 29, 2012, 02:38:01 AM »
Naturlich Schwingenlager Bronzebuchsen  - lieber Freunde  ;D
How do you like them?
Offline wrenchmuch
« Reply #13 on: November 29, 2012, 07:29:09 AM »
Hondas replacement parts seem to be steel these days. Don't bother with them. Steel on steel doesn't last too long.
Bronze or Oilite is the best type of replacement. Have a good look at the collar. It's the hollow tube that goes inside the bushings. If it shows wear it should be replaced as well. A rough collar will tear up the new bushings. Hondaman has a service to replace bushings with Oilite bronze and size everything for good tolerance. Worth the money if you can afford it.
CB750K1
CB750K4
« Reply #14 on: November 29, 2012, 08:40:52 AM »
Hondaman - local guru - replaces bushings as a service, but you have to ship it to Denver:
http://forums.sohc4.net/index.php?topic=58828.0
Offline CycleRanger
« Reply #15 on: November 29, 2012, 03:51:14 PM »
They went in fine. And when used in a 750 you don't need the plastic "top hat" pieces or the felt rings, just the caps.
« Reply #16 on: November 29, 2012, 04:16:21 PM »
Top Hat refers to the shape of the bushing. Either a barrel or a top hat. The ones in question are "top hats".
The plastic end pieces are "thrust bushings". They can be deleted when converting from barrels to top hats.  That's the way I've come to know them anyway.
Granted, the thrust bushing is replaced by the top hat portion of the replacement bushing.
« Last Edit: November 29, 2012, 04:18:17 PM by MCRider »
Offline srbakker
  • Spam & Eggs
« Reply #17 on: November 29, 2012, 05:46:52 PM »
If it helps, I have a new set of bronze bushings you can have on the cheap ( much cheaper than $50, anyway).  Lemme know.
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline alacrity
  • Ride, Optimize, Repeat
« Reply #18 on: November 29, 2012, 11:13:03 PM »
Here's a link -- I wrote up what I did because I hated the idea of going at them with a hacksaw. Hope this helps:
http://forums.sohc4.net/index.php?topic=104216.msg1165478#msg1165478
  • 1975 CB550K
« Reply #19 on: November 30, 2012, 10:02:35 AM »
Good write up. Did you swap the bushings before or after you powdercoated?
Offline iron_worker
« Reply #20 on: November 30, 2012, 10:32:26 AM »
I definitely stole your idea. Just for the record. lol
It works great btw. Thanks!
IW
Offline Bankerdanny
  • Endeavor to persevere
« Reply #21 on: November 30, 2012, 12:40:09 PM »
If you are
If you are removing them they must need replacing, because if they do not need replacing then there is no reason to remove them.
  • 1975 CB550K
« Reply #22 on: November 30, 2012, 02:32:01 PM »
I was thinking there would be a lip that you bang on to get them out. Looking into the cylinder, I don't see any lips. It just looks like a long cylinder in there. Is that correct?
Offline slyguy
« Reply #23 on: November 30, 2012, 03:22:01 PM »
That's what I thought too after removing the long collar tube thingy..lol It's actually just grease packed around the interior bore. get a screwdrive to scoop/dig it out, you'll see..:)
  • 1975 CB550K
« Reply #24 on: December 01, 2012, 10:43:10 AM »
What is the long collar tube thing? I have only take out a big bolt with the grease zerks on it.
