Author Topic: Electronic Ignition  (Read 5388 times)
Offline thenewbie
  • Tits migee
Re: Electronic Ignition
« Reply #25 on: December 08, 2012, 06:33:19 PM »
Well I got the bike to run today (bought the pamco ignition to save from headaches). It runs ok. I couldnt get it to idle but it may have been because it wasnt warmed up? Anway the header from cylinder #1 wasnt as hot as the other 3 so after I shut it off I pulled the plug and it was damp. So if I sync the carbs would that clear it up?
1976 cb550f, 1995 xr250l
« Reply #26 on: December 08, 2012, 07:02:08 PM »
Unlikely.
Swap plugs and see if the problem follows.  Other wise, it's probably a carb issue.
Offline thenewbie
  • Tits migee
« Reply #27 on: December 08, 2012, 07:14:13 PM »
If I do end up needing to replace a plug should I replace all 4 or just the one? Because supposedly the plugs were replaced only about a year ago or so.
« Reply #28 on: December 08, 2012, 09:30:49 PM »
Anything man made can fail.  And, there is no time guarantee.  A year ago is a long time under some conditions.  The bike ran well 30 years ago, now it doesn't.  Other bikes run well that are older.
A carb providing too rich a mixture can make an otherwise good spark plug fail due to excessive carbon deposits.
We don't have a good description of the spark plug deposits other than "damp".
However, "damp" indicates the cylinder not firing, which can be a bad plug, a fouled plug, or connection issues.
That is why I outlined a minimal diagnostic process.
Stop trying to jump ahead, and do the work and investigation to determine true cause.  Or, just keep throwing money and parts at the problem along with "hope".
Your choice.
Offline thenewbie
  • Tits migee
« Reply #29 on: December 08, 2012, 09:33:14 PM »
ouch
« Reply #30 on: December 08, 2012, 09:39:11 PM »
how old are the plug caps?if you have a multi meter you can test them.
« Reply #31 on: December 09, 2012, 06:41:36 AM »
TT is right. Now you can drill your problems down by swapping parts around and finding the real issue. You almost there, keep going :)
« Reply #32 on: December 09, 2012, 08:58:32 AM »
TT is right. I think you have a carb throwing a rich mixture and fouling a plug. Ignition usually fails in pairs with the waste spark system. If I had a bad connection on #1 then 4 would misfire also. Look at your float levels and yes I would buy new plugs at Autozone they are fairly cheap.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #33 on: December 09, 2012, 09:37:33 AM »
Hee hee, whinging about points. Try owning a Kawa triple.  :D
« Reply #34 on: December 09, 2012, 10:34:33 AM »
Or a Trident or Rocket 3.  ::)
« Reply #35 on: December 09, 2012, 07:04:15 PM »
Did you know I make a Hondaman ignition for those, now? ;)
  • 1977 CB550F2
« Reply #36 on: December 10, 2012, 02:53:29 PM »
I did Mark but the triples are long gone.  :(
Offline thenewbie
  • Tits migee
« Reply #37 on: December 11, 2012, 04:45:16 PM »
On a side note I did notice that one of the carb floats was a blue-ish color like it had been burned or something. Anybody know what that means?
« Reply #38 on: December 11, 2012, 09:51:21 PM »
Usually that's because someone used the old-fashioned "gas preserver" that used to have formaldehyde in it. Once the stuff dried out, it stained the floats, and often the bowls. Avoid that stuff in the future: it doesn't work with ethanol-laced gas, makes a real mess of these carbs.
