Author Topic: AMAZING Gas Tank Rust Removal Trick!  (Read 12611 times)
Offline phil71
Re: AMAZING Gas Tank Rust Removal Trick!
« Reply #25 on: December 08, 2012, 04:57:57 PM »
OH , i don't know what battery.. what ever I have around that holds a charge really
Offline ncstatecamp
« Reply #26 on: December 10, 2012, 02:03:27 AM »
this may be a stupid question/suggestion (since i dont know that much about metalurgy). After you've removed the rust would it make any sense to reverse the process and add some copper plate to the inside? I know they use a bit of copper in carbs so its fine for gas. Would this be helpful?
« Reply #27 on: December 10, 2012, 03:23:25 AM »
I tried this awhile ago with pretty disappointing results. It works, but is slower than a wet week in winter, so I gave it the arse and bought a gallon of "Phos-Wash" (phosphoric acid based dairy equipment cleaner) and cut it 1:3 with tap water and filled my tank up, (cut a rubber bung so I wouldn't have to bugger my petcock) and swished it aound every other hour.
Next morning I dumped it out, flushed and dried the tank, and it's like new inside. Unlike most acids, phosphoric acid doesn't attack your paint either. Cheers, Terry. ;D
« Reply #28 on: December 10, 2012, 05:28:21 PM »
I discovered that it is hard on bluejeans, however!
« Reply #29 on: December 10, 2012, 10:32:44 PM »
Not if you're not wearing any pants Mark! ;D
Offline Esprit Performance
« Reply #30 on: February 24, 2013, 03:10:07 PM »
For gas tank rust removal, Chewbacca has documented the use of non hazardous rust remover from http://www.rustdepot.com/. The post is here: http://forums.sohc4.net/index.php?topic=95114.25
Wondering if grcamna2, GSX69bun, AEngelsrud, Irutt or others have any feedback and/or photos of their tanks using the Esprit
« Last Edit: February 24, 2013, 03:20:08 PM by Esprit Performance »
More info on chelant type rust removers and their uses is found at http://rustdepot.com
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #31 on: February 24, 2013, 03:43:53 PM »
Beautiful bike. Have used baking soda, battery charger, plate steel, and water in a 5 gallon plastic bucket for derusting springer frontend springs and various other loose parts like brake levers and hardware.  Works great, fun to watch bubble.  I have used the works toilet bowl cleaner on rusty seat pans in the same bucket with water.  Stick it in, wait 3 hours, flip, another 3 and done.  Unlike sandblasting, i can mow the yard while it works.
Offline Hondawggie
  • Flimmy-Flammy, Hambone-Sammy -- I'm a Bigole
« Reply #32 on: February 24, 2013, 08:10:42 PM »
I used the works toilet cleaner on my sportster tank,worked like a charm
Pinhole leaks though -- that is a possibility -- but after my riding buddy showed me a cleaned Yamaha tank that had been rusted I went out and bought the same type of toilet bowl cleaner and read up on it -- turns out this bowl cleaner was muriatic acid which is a weak form of hydrochloric acid supposedly -- all the reading I did on it say that if you miss any during the rinse, if any is left behind in nooks and crannies you'll get pinhole leaks in the tank
Anyone seen nice looking gas tanks with 'unexplained' pinhole leaks?  I have.
I use Phosphoric acid on my rusty tanks.
But dang the job that muriatic acid does on a rusty tank is incredible, compared to the 'before' so it's real tempting.
I like this battery trick and am gonna try it, thanks dude!
Offline Hondajohn88
  • Cut myself the other day:Lost a quart of Honda oil
« Reply #33 on: February 25, 2013, 05:08:30 AM »
I just did the 2 gallon cheap vinegar and Dollar store aquarium rocks thing
Swished and turned a few times over a day long period
Rinsed with diesel ,rinsed that with gas then filled my beatifuliy cleaned tank with clean gas!
kept the used fuels in old vinegar jar for future paint brush cleaner or whatever
same with vinegar but strained through nylon sock in funnel and will reuse for next tank....ps. had  about afist size clump of rust deposit in nylon after straining
Stinky and a bit messy but no damage to the paint and please use safety glasses if you try any of these methods guys....and gals
4 -K7'S
2- K8'S
2008 VTX1800
« Reply #34 on: February 25, 2013, 06:45:00 AM »
What are those?
Offline kybushdr
« Reply #35 on: February 25, 2013, 01:04:36 PM »
Hate to throw a chemistry lesson into the mix but citric acid neutralizes iron oxide.  I got citric acid in a powder form (websites for making bath powders, scented bath stuff etc...). Mixed with water, put In my cb350f tank, let it sit overnight and poured it out in the grass.   Harmless, non-toxic (didn't kill a blade of grass, heck you could drink it) and my tank was bright, rust free and shiny.  I put the stuff in plastic containers to soak rusty tools and parts, no fumes, no electricity, works great.   Will not plug holes/synthesize new metal, but it sure sounds safer and easier than all this other stuff.   All the best,  Kentucky Ken
Offline Tews19
  • I am no
« Reply #36 on: February 25, 2013, 09:11:33 PM »
Ken I'm curious you mixture ratio? I see 2lbs can be had for 11 bucks. I've done evaporust, works great but expensive. Vinegar is good for a tank I've done but this tank I want to clean is pretty rough.
1970 Honda CB750 survivor.
Offline kybushdr
« Reply #37 on: February 26, 2013, 01:40:52 PM »
A teaspoon per quart, a cup per gallon, I should warn you about the timing, I had a backup tank just in case.  It would be safer to fill the tank and empty every hour into plastic container.   Then check the progress of your rust removal, if it needs more time, pour back from plastic container into tank, check in an hour etc..... my personal experience has been that it has never done anything more than remove the rust, but acid is acid, better safe than sorry.    All the best
Offline kybushdr
« Reply #38 on: February 26, 2013, 02:25:26 PM »
Sorry, cup is too much per gallon, 10% solution so 1 part citric to 10 parts water and always add powder to water, never water to powder
Offline Hondajohn88
« Reply #39 on: February 28, 2013, 04:37:45 AM »
What are those?
The little coloured round  about half inch size stones  ,quickens the removal of really thick rusty gook in when you shake it round with vinegar .
4 -K7'S
2- K8'S
2008 VTX1800
Offline 74CB400FFourSS
  • Cafe for life
  • 75 CB400F Super Sport
« Reply #40 on: May 07, 2013, 03:11:51 PM »
Has anyone tried vinegar?
Rob
1975 CB400F Four SS
Offline new2bikes-again
    • wellandpond.com
« Reply #41 on: May 07, 2013, 05:57:26 PM »
74CB400, yes I've done the vinegar. I was happy.
http://forums.sohc4.net/index.php?topic=112255.msg1261004#msg1261004
Offline Rudi91
« Reply #42 on: May 08, 2013, 12:56:34 AM »
What do u do with your fuel cock/cup while doing this?
Won't it get filled with rust?
I was thinking about disasembling it and replacing it with a screw so the tank isn't open at the bottom.
CB350F '73
Offline acollin
« Reply #43 on: May 09, 2013, 06:34:48 AM »
I too used " evapo rust" and there are companies making like products. I found the stuff remarkable. It was not as inexpensive and the "electrolysis", but the tank is grey again on the inside. I bet you could drink the stuff.
Paint was unaffected. I put about 50 golf balls in the tank to take up the volume and save a little cash. I let it sit for a few days- repositioning the tank every so often. I bought it at Harbor Freight.
Not cheap, but it was trouble free and persevered the original paint.
« Reply #44 on: May 09, 2013, 09:27:32 AM »
If youpute steel parts in vinegar, and add a piece of copper pipe the steel parts will get  a thin layer of copperplate.
Offline jason41987
« Reply #45 on: May 09, 2013, 03:20:02 PM »
i used this method on my tank.. i didnt complete the process, only did it about half way.. i used baking soda which isnt as efficient as washing soda, but it cleaned up a lot of the rust
as for the sacrificial piece of metal... your best bet is to have as much surface area as you possibly can... threaded rod would work VERY well and what i do after the sacrificial piece of metal gets a thick enough layer of rust on is i clean the rust off with a brass brush in my dremel to expose more un-corroded steel
Offline jason41987
« Reply #46 on: May 11, 2013, 05:09:28 PM »
i just got an idea that im testing out now with good results... see, the goal is to have a sacrificial piece of metal to collect the oxygen and to form the rust... some people use rebar.. but the goal is to have as much surface area as possible, and its good to mechanically clean the rust off of the sacrificial piece of metal every so often so more clean metal is exposed
my idea was to use a piece of small diameter plastic rod... something non conductive because we want this piece to be reusable... then what i did was took some steel wire and wrapped it around this piece... this steel wire will collect the rust, and instead if cleaning the rust off, i can simply re-place the steel wire wrapped around it... and since the wire is coiled around it gives much, much more surface area than a chunk of steel alone would, which will increase the efficiency of the process, and clean the rust even quicker
ill take a photo of my tank when its clean.. both inside and out as i have a USB borescope i can stick in and look around with and take some photos of the inside from another perspective, from inside the tank... then i was actually going to give it a once-over with some rust reformer to get any bits of rust that may still exist where i cant see it, then line the inside of the tank with red-kote (this tank had a hole repaired onces before, so im not sure i trust it enough to not coat this particular tank
Offline ncstatecamp
« Reply #47 on: May 11, 2013, 05:43:31 PM »
How's that? Don't you need an electrical charge?
Offline MJL
  • Don't listen to me, I'm no
« Reply #48 on: May 11, 2013, 08:09:31 PM »
which is it? 1;10 comes out to 13 oz acid to one gallon, one cup is 8 oz
I've got some vinegar and have done the vinegar treatment to other rusty things, but I didn't like the way it continued to eat away at the base metal and flash rust when it was dry so I bought some citric acid and want to try.
« Last Edit: May 11, 2013, 08:14:12 PM by MJL »
« Reply #49 on: May 11, 2013, 08:11:52 PM »
No electricity, i was a bit surprised.. Seems the copper gets into solution and and the steel attracts it.
