Author Topic: Using the kill switch  (Read 9978 times)
Re: Using the kill switch
« Reply #25 on: December 05, 2012, 05:55:11 AM »
This topic popped up before and it turned into a rather heated debate and I never could understand why.
Note lucky's post and the, I am right and this is the only answer attitude.  You don't really wonder why the heated debate do you.
I was wondering if that bothered anyone else than me, thanks for posting.
Offline MoMo
  • Ride like you're invisible
« Reply #26 on: December 05, 2012, 06:02:52 AM »
Just to be different - I almost always use mine.  As was mentioned, I can kill the bike before I let go of the bars.
It's a routine - kill switch off, headlight off, key switch off, gas off. :)
Have followed that routine for 40 years...Larry
Offline Tews19
  • I am no
« Reply #27 on: December 05, 2012, 06:04:23 AM »
What happens if you hit the kill switch on accident while riding? Power is lost but does the engine then freeze up when in gear ? I wonder?
1970 Honda CB750 survivor.
Offline CB500_k2
  • Wrenching makes a good retirement.
« Reply #28 on: December 05, 2012, 06:04:42 AM »
I use the kill switch for a starting routine for my hard to start in the cold CB500.  Open the kill switch, choke full on, open throttle wide, hit starter for about 5 seconds, close kill switch, crack throttle just a bit, hit starter button  and off she goes.  I am not quite sure what the logic is, but it does make it easier to start the old girl.  The procedure was suggested to me by my brother who is a motorcycle mechanic and old bike aficionado.
Too many bikes -- too little time
1973 CB500
1974 CB350 - sold
1975 CB400F SuperSport
2000 Ducati Monster Dark
Offline knowsnothing
« Reply #29 on: December 05, 2012, 06:05:13 AM »
I use the kill switch, key and turn the gas off.  I figure if someone is going to try and nick the bike, all the steps will slow them down and even then they might not get far  ;D
1978 CB750k Blue - for sale
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #30 on: December 05, 2012, 06:07:09 AM »
It backfires, just like a car when you flip the ignition off. The unbrunt fuel explodes and boom! It's running again..
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
« Reply #31 on: December 05, 2012, 06:10:36 AM »
Everything will be fine. I have a riding buddy and one of our fun pranks is to swoop up and turn off the other guys kill switch then nail it leaving them momentarily in the dust.Only way I can keep up with his punched out Z1.
Offline bjatwood
  • 1973 CB750-K3
« Reply #32 on: December 05, 2012, 06:12:46 AM »
I believe the logic is your "priming" it a bit with fuel to start. Kindof like when we had carburated cars/trucks. You pumped the pedal a couple times to set the choke and pump some fuel into the cylinders to start it. I kick my K3 with the fuel on and the choke on, and a bit of throttle.... if it's been sitting a couple weeks. Then just a push of the starter button and it's running. Followed by turning the full choke off immediately to about 1/2 way. This seems to be a good technique for my bike..  8)
Brian
#24193
« Reply #33 on: December 05, 2012, 06:16:47 AM »
The engine does not freeze up. It coninues to turn thru, though under full compression braking. Sort of like cutting the throttle from speed to idle, and applying a little brake. Nothing hazardous. One would instictively grab the clutch lever under that circumstance, then regroup.
As bjatwood says, though not completely, if you've left the throttle open, when you turn the switch back to on you'll get a horrendous backfire. we used to do that on purpose, great fun.  ;)
But if you cut the throttle and give the pipe time to clear out you won't get the backfire.
Offline Gordon
  • 750K1, 550K2
« Reply #34 on: December 05, 2012, 06:19:28 AM »
I do the same thing on especially cold mornings, except I just leave the ignition turned off for the first couple of kicks, and then turn it on to start.  It primes the cylinders and makes it easier to start, essentially increasing the choke.
« Reply #35 on: December 05, 2012, 06:55:18 AM »
I rarely use mine, no need to I guess.
« Reply #36 on: December 05, 2012, 09:09:17 PM »
I've used mine and then got distracted and left the key on. So I usually try to use the key switch, sometimes if I want to leave it in gear (hillside etc) I'll use the kill and then switch off then petcock.
Offline Bailgang
  • Scott
  • Indiana
« Reply #37 on: December 06, 2012, 02:15:02 AM »
I learned very early when I first joined this forum that that is just the way Lucky is take it or leave it and I must admit that if you can cut through the "attitude" he does come up with helpful advice and worth listening to so I just deal with it and welcome his opinion.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline jamesb
« Reply #38 on: December 06, 2012, 04:52:10 AM »
That's my problem too. I get sidetracked and leave the key on then wanna go some where and have a dead battery because the light is on.
Offline Dream750
« Reply #39 on: December 06, 2012, 05:45:33 AM »
The most important thing is that the switch functions correctly, no matter what method you prefer. Photo is from the CB750 owners manual:
« Reply #40 on: December 06, 2012, 05:49:45 AM »
The term "primarily" implies that there are secondary uses as well. If there weren't there would be no reason to qualify it primarily and would just say "only".
Offline Dream750
« Reply #41 on: December 06, 2012, 05:59:50 AM »
MC, that's also the same way I understand Honda's description & terminology.
« Reply #42 on: December 06, 2012, 06:06:35 AM »
Since I opened this can of worms, I feel obliged to comment that it is nobody's business how you use the switch.
I was just curious how other people do it  ;D
« Last Edit: December 06, 2012, 06:26:27 AM by 70CB750 »
Offline LoVel
  • Yes, I remember your mother well. She was quite the
  • 1972 CB500 four
« Reply #43 on: December 06, 2012, 06:23:48 AM »
Yeah, what I do to my motorcycle is between me and my motorcycle and neither one of us is talking.
On another note I rode the CB this morning after she has sat for a few days and tried the kill switch open method.  Opened the petcock and choke, kicked her a few times gently just to turn her over,  opened the kill switch connection,  turned on the ignition and hit the starter button a couple of times, closed the kill switch and hit the starter and she fired right up.  Love it.  Thanks for the info.
« Last Edit: December 06, 2012, 06:33:42 AM by LoVel »
I'm an individual,  just like everyone else.
Offline 750K
« Reply #44 on: December 06, 2012, 10:24:23 AM »
But how do you know it's working propperly if you aren't using it, bahahaha.
77 Cb750, 78 Kz1000
« Reply #45 on: December 06, 2012, 10:47:48 AM »
I flip it by accident at least once a month - I know it works  ;D
Offline ssolla000
  • 1980 yamaha cafe bobber, 1979 cb650, 1994 bmw k75
« Reply #46 on: December 06, 2012, 07:59:47 PM »
I dont use the kill button, or kickstand,, I just swing my leg over running and all and just let it fall over... i just dont like the idea of killing my bike.....  :o
Offline Cabilao
  • Diving and Driving
    • Sea-Explorers Watersport
« Reply #47 on: December 07, 2012, 12:39:14 AM »
thats it!  8)
before:
Kreidler RMC(50cc)
CB400N(first bike)
RD350LC(more than one)
XS850(great bike)
CB900F(wish i still have it)
FZR1000(too fast)
Rickman CR900(sold for a good price)
now:
Rusi 125
CB 125 CL(just for fun)
Yamaha XTZ 125
CB750P7(mystery bike)
77/78 cool 2 member
« Reply #48 on: December 07, 2012, 02:52:27 AM »
?bang?
Offline LoVel
  • 1972 CB500 four
« Reply #49 on: December 07, 2012, 01:04:12 PM »
DHAFC
