Ok let me clarify so that I undersatand what you mean.
You have a 750 that used a mono shock swing arm from either a GSXR 1100 or 750 that was a direct fit with no machining to your Honda CB 750 frame? The pivot bolt size is the same and you did not need to modify the hole or frame?
Yes, the swingarm is a shortened GSXR1100J 1988 model, direct bolt in.
In an earlier post you mentioned the GSXR 1100 and 750 with 4.5 inch wheels , but you did not mention the years they were produced?
Considering you are in Australia and I'm in the USA were there any differences in the models in our respective countries?
No differences, the models were the same. The 1100's with 4,5 inch rims are, 1988 GSXR1100J , first model 1100 with 3 spoke rims, the sizes were 18x2.75 front, 18x4.5 rear, the GSXR 1100K 1989 model had 17x3.5 front and 17x4.5 rear, the 1988 GSXR 750J had the same size rims as the 1989 1100K.  Bearing sizes may differ between models but thats easily fixed as they are common size bearings.
Yesterday I visited a motorcycle salvage yard with micrometer and ruler and could not find a GSXR swing arm that had a pivot bolt small enough [15mm dia.& 13 inches long] that would fit my Honda CB 550 frame. All of the swing arms had 17mm to 20 mm pivot bolt diameters. They also were from either the late 90's or early 2000's. So can I assume your swing arms are from earlier bikes
Yes, the earlier GSXR parts are the ones that fit, forget the later model stuff as its a lot harder to modify...
I posted this link earlier in the thread, go have a read, he uses an early GSXR 750 swingarm {GSXR750 G-H, 1986-1987} and wheels {not the 3 spoke wheels}
  I would PM the guy in the link i posted below as it is a 550 and he races his bike , it is set up well, looks great too...
http://forums.sohc4.net/index.php?topic=63938.0
