With the caliper unbolted from the fork legs, will it slip easily over the disc? If yes, this indicates an alignment issue. If no, then the pads are too thick, or are not seating fully in the caliper. Do you have the nylon ring that fits between the piston and pad properly in place? If it is not centered on the piston, it can push the active pad outwards by about 2 mm.
