sso one or more of my floats is definitely sticking. tried to fire it up last night and it started pissing gas all over the floor. could not trace it from the hoses as I was more concerned with cleaning and stopping the flow first. that hopefully explains my strage stuttering behavior. so now I have to determine why my floats are sticking when they are brand new. my first and unfortunate guess is the gas is gumming them up from the POR15 coating in the tank. I can't imagine there being that much debris in gas naturally to clog up the slow jets and make the floats stick. gumminess has to come from something not normal ie. the Por-15 coating. if this IS the case I'm not sure how to proceed. how can I be sure the coating is coming off?
it was really suck to try and recoat or just strip out the existing coating because of my fresh paint on the outside. I am 100% the application was done correctly, my tank was super bone dry before the coating went in. if it is failing it is failing though, no getting around that.
I also ordered the starter motor brushes, 3 8x14mm metal dowels, and a stator cover gasket.
