update. last night I finally got one fork out thanks to advice here! put the caps back on the forks and put a slightly oversized (I dont have the right size) socket on the cap and beat it with a dead blow hammer until the socket was sunken down below the fork ear. then I was able to have enough starting leverage to slowly, and I mean SLOWLY twist the fork out
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2848.jpg)
got both of them out. well theres your problem, I feel like these should be silver colored
![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2850.jpg)
here is my fork oil. awesome
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2854.jpg)
found an adjustable spanner and pulled the lower triple off. thats some nasty grease. got all the balls.
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2851.jpg)
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2852.jpg)
hmmm, gotta get those races out.
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2853.jpg)
got the races out of the neck with some torch work, a long flathead screwdriver, and a dead blow hammer. not too bad.
as she sits not. about to take off the centerstand. just cleaned 1/2" of crud off of the bottom area of the frame. nasty. also, I think one of the feet (not the one with the foot lever) was welded on at a later date. it looks like it was welded crudely, and the centertand does not level the bike. it leans slightly towards the left side (if you were on the bike). should I address this now with a new centerstand?
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2855.jpg)
got the rubber brake line and metal line off
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2856.jpg)
also got both of these bolts of with lots of man force!
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2857.jpg)
I am pretty sure thats the top of the lower neck bearing still attached here so I have to try and remove it. prying with a screwdriver is proving fruitless so far :/
![](http://i211.photobucket.com/albums/bb30/jusballs13/IMG_2858.jpg)
thanks for reading! now onto figuring out how I want to refinish the frame, swingarm, etc. pretty sure I'm not going to powdercoat, does anyone have any nice black frame
