Author Topic: new tubing bender bending .058 wall  (Read 2960 times)
« on: December 16, 2012, 08:22:37 PM »
I've been working on this for my racecar project. Wondering what I can build for my bike. Right now I have an 1 1/4" od tubing die set on the way.  Will bend .065 and thicker. I might try 16 ga exhaust at some point.
Not shown, base and hydraulic cylinder.
« Last Edit: January 08, 2013, 08:23:31 PM by Don R »
Re: new tubing bender
« Reply #1 on: December 16, 2012, 08:52:26 PM »
 The instant I get my hands on one, should be in the next few months..I should have access to one..
...I have to start on the dies to bend up some highpipe parts..
« Reply #2 on: December 16, 2012, 08:57:24 PM »
This resembles a #2 hossfeld, except for the hydraulic and brackets. I borrowed a #1 to build it with. It bent the 1/2"x 3 1/2" bar stock easy. I'm buying the tooling from Hossfeld, American bender looks to be the same design.
« Reply #3 on: December 17, 2012, 10:12:07 PM »
The die set showed up today and I can see the bracketry on the right is all wrong. minor inconvienience. Fooey.
« Reply #4 on: December 18, 2012, 02:49:24 AM »
That looks interesting Don, will it do nice wrinkle-free tube bends? Cheers, Terry. ;D
« Reply #5 on: December 18, 2012, 09:43:47 PM »
Yes it needs .065" or heavier though. I'm thinking that's around 15 gauge. I forget the MM. They use the same one at RJ race cars our local NHRA and ADRL pro stock/pro mod builder. There are dies available to do almost any metal work.  Even a punch and a shear. Williams low buck tools sells one,  American Bender and the Original Hossfeld.  I cheaped out and built my own.
JD2 has a different design bender that's less expensive, my experience has been on one of these.
With the hydraulic, any of them will bend 2" x 1/4" wall.
« Last Edit: December 18, 2012, 09:47:35 PM by Don R »
« Reply #6 on: December 19, 2012, 02:23:19 AM »
Looks great mate, what are you going to use it for mainly? I think our headers are either 1 1/2" or 1 3/4"? Can you buy those size dies, and are they expensive? I'd love to make my own pipes! Cheers, Terry.  ;D
« Reply #7 on: December 20, 2012, 07:53:59 PM »
I'm building it to bend the tubing to backhalf the dragster. I had a chassis shop add a swingarm/coil overs suspension few years ago and the builder made some poor choices which led to cracks this year. It's been parked since june.
 The changes I decided to make are coincidentally in the new SFI chassis spec. rule book. Guess I'm not the only one to see this same problem.
 I just bought the 1 1/4" die so far, it's about  $250.  Hossfeld sells dies for bending almost any metal you can get. flat, angle square etc. I've seen guys buy the next size die up, then bend a tube, slice it to make a shoe to shim the die for the next size smaller tube. We  use a lot of .058" wall because it slip fits into the next size
« Last Edit: January 12, 2013, 07:20:41 PM by Don R »
« Reply #8 on: December 26, 2012, 08:24:07 PM »
New picture, ready to rock.  I released the order on the tubing today so I can go pick it up.
« Reply #9 on: December 26, 2012, 10:40:24 PM »
That looks great Don, what about a pic of the bent tube too? Cheers, Terry. ;D
Offline mono
  • Definitely no
« Reply #10 on: December 27, 2012, 05:36:44 AM »
wow that's a nice looking machine.  good job :)
Offline Killer Canary
  • Typical Bran Muffin
« Reply #11 on: December 27, 2012, 05:56:15 AM »
Can't wait to see some headers. :D
Kawi GPz900, H1
« Reply #12 on: December 27, 2012, 10:21:04 AM »
I'm hoping my buddy that works at the race car shop can provide some short pieces to practice bend, the part in the die is the upright for the chassis so I haven't bent any tube yet. I'm picking up my order today.
« Reply #13 on: January 02, 2013, 11:40:49 AM »
It appears the blueprint is incorrect, the 1 1/4" wont bend properly. The pins shouldgo in the 5th holes and tube wont load. According to someone that owns one the c-c should be 5 5/8" but it's 5 3/8". I don't know if the spacing of the holes are off or just the starting point. Anyone want to start drinking in the afternoon?
« Reply #14 on: January 02, 2013, 06:37:16 PM »
Toast.... to Don  ;)
« Reply #15 on: January 03, 2013, 12:58:29 AM »
I've been drinking all day..................... ;D
Offline BLUE71TURBO
« Reply #16 on: January 03, 2013, 01:25:18 AM »
« Reply #17 on: January 03, 2013, 02:29:31 AM »
That's slick too, I wonder how it re-sets to bend it farther?  I hadn't seen the video, that's the JD2 bender If I hadn't been given the steel and found the print I would have bought one of these.
« Reply #18 on: January 03, 2013, 03:38:07 AM »
That looks like pretty thick walled tubing guys, will one of those benders do exhaust tube without wrinkles? Cheers, Terry. ;D
« Reply #19 on: January 05, 2013, 07:59:20 AM »
Yrp. the blueprint was wrong. Story of my life. I knew it was a leap of faith to use it. It looked so well drawn I trusted it. The holes should be 1.1" apart which makes them .035 short x each hole adds up to around 1/4" at the 5th hole. Idropped 5/8" pins in instead of the 3/4" and it falls into place. Might get this project bent before I weld it back up and start over. Next time it goes in a mill to make the holes.
« Reply #20 on: January 05, 2013, 03:30:22 PM »
I used 5/8" pins instead of the 3/4". that allowed for the difference in the drilled holes. The 1 1/4" bent perfectly. Now my camera phone is on the fritz. pictures when I can.
« Reply #21 on: January 08, 2013, 08:23:01 PM »
Re: new tubing bender bending .058 wall
« Reply #22 on: January 08, 2013, 08:26:45 PM »
The #5 hole is off 1/4" so I made 5/8" pins to replace the 3/4" ones to temporairly make it work. 1/8 two times = 1/4"
 This is 1 1/4" .058 chrome moly.
« Reply #23 on: January 09, 2013, 03:07:28 AM »
Sweet!
Offline mono
  • Definitely no
« Reply #24 on: January 11, 2013, 01:53:20 PM »
Lookin' good!  that's quite impressive.   glad it's a success! :)
« Reply #25 on: January 11, 2013, 02:55:36 PM »
Is it just my eyes, or just a trick of the light, but that doesn't look like a smooth, uniform bend Don?  :-\
« Reply #26 on: January 11, 2013, 06:20:22 PM »
It's the light, my picky friend that builds NHRA pro stocks and pro mods approved of the bends. I sprayed oil all over everything and it's an old piece of tube shiney here and there.
« Reply #27 on: January 12, 2013, 02:39:32 PM »
That's good to know Don, as I'd like to build one of those benders too. Cheers, Terry. ;D
« Reply #28 on: January 12, 2013, 07:18:27 PM »
http://www.kinzers.com/don/MachineTools/bender/
Here are the blueprints I used.  Be warned, on the main frame and the swinging frame the c-c distance between the holes is incorrect. It shows 1 1/16" it is really closer to 1.1" From the center pin to the #5  25/32 hole should be 6 5/8" the print adds up to 6 3/8"
 Who knows what else might be incorrect. Repeated attempts to contact him have failed.
« Reply #29 on: January 13, 2013, 03:14:58 AM »
Thanks Don!  ;D
