Support the site. Your contributions keep this site running.
She appears to be highly customized. Fear not, lots of years parts interchange and there is no accounting for the actions of a PO. (Previous Owner) A nice riding bike can be delivered from your investment. The search function on the left works and if you choose your words wisely it will turn up a gold mine of information. Be sure to read FAQ's and tips and tricks. An Excellent book is available written by our own resident expert Hondaman. You need to have patience and enjoy learning about these fine machines. The swingarm apperas to have lowering blocks of some sort. Hopefully they are removable, if you are inseam challenged you might consider leaving them although they will have some effect on handling.
You would then have a 77' neck welded to an earlier frame. Look at the connections between the steering neck and the frame to be sure it wasn't "cobbled' together. If done properly you should be fine, otherwise this is a bad location to make compromises. I would suggest comparing this part of the frame to another CB750 frame to see any potential deficiencies. There's a slim possibility that the numbers were "restamped" onto the older frame.
....but it has a 17" rear wheel?
