Author Topic: Vintage CB750 handlebar switches  (Read 4455 times)
Offline srbakker
  • Spam & Eggs
« on: December 21, 2012, 01:05:21 pm »
I just got an email from www.vintagecb750.com that they are stocking handlebar switches for a pretty wide variety if cb750s.  Anyone know if these are OEM or repro, and if repro, are they any good?  I gotta say, despite repainting and rebuilding my own switches, I'm pretty tempted by this...
http://www.vintagecb750.com/products/86/new-items
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
Offline Prospect
Re: Vintage CB750 handlebar switches
« Reply #1 on: December 21, 2012, 03:11:22 pm »
I'm pretty sure those are repo. Too inexpensive to be oem. Plus I dont think he sells any oem stuff. If they're of equal quality as the repo ignition switches floating around then I'd stay away. Incorrect gauge wire is being used and can cause melting.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
« Reply #2 on: December 21, 2012, 03:13:29 pm »
Dumb question, where's the high beam switch on those switches..?
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: December 21, 2012, 03:38:49 pm »
The bottom half of the left-hand switch housing.
« Reply #4 on: December 21, 2012, 03:43:59 pm »
They are def not OEM, but look to be pretty decent. Worth a shot at that price.
« Reply #5 on: December 21, 2012, 03:47:58 pm »
I remember reading (HM book??) that you should use those switches with relays. They are not built to handle much amperage.
Offline srbakker
  • Spam & Eggs
« Reply #6 on: December 21, 2012, 03:59:52 pm »
Hmm.  Sorta kills the price and convenience advantage if I have to build in relays and find a place to put them.
1975 CB750 K5
2007 Triumph Tiger
« Reply #7 on: December 21, 2012, 04:19:01 pm »
Thanks Gordon, we got the high beam switch on the right hand control here...
« Reply #8 on: December 21, 2012, 04:44:47 pm »
The first 2 switches on the site will drop right in to the K3/4/5/6 bikes. The third switch will fit the F0-F3 and K7/8 bikes.
The only wires that, if undersized, would be of issue would be in the right-hand switch, the START button might need a Relay Kit to prevent switch heating if halogen headlight is used. If stock headlight (Stanley or sealed-beam type) is used, no problems should crop up.
The K0-K2 bikes (like those built for AUS and UK until 1976, US until 1973 early) have an OFF/LO/HI on the right side, and no HI/LO on the left side. This early wiring is different from the switches on this site, but they can be adapted if required. PM me for details if you need them.
« Last Edit: June 17, 2014, 10:20:32 pm by HondaMan »
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: December 21, 2012, 04:55:54 pm »
Makes sense.  I guess since it's a motorcycle and they couldn't mess things up by putting the driver's seat on the wrong side they just screwed around with what they could. ;D
« Reply #10 on: December 21, 2012, 09:42:34 pm »
They just added another step to the on off switch... Same as the Japanese bikes... ;)
Offline RSchaefer
« Reply #11 on: December 23, 2012, 06:21:50 am »
If you read Randy's (http://www.rcycle.com/HondaCB750GaugeRestoration.html) blog on his CB750K resto he purchased switch controls supposedly directly from Honda and they were obviously out-sourced and he said the kill switch ended up being purple rather then red for what its worth.  Based on the pictures from the Vintage site they do look red however.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Offline srbakker
  • Spam & Eggs
« Reply #12 on: December 23, 2012, 06:40:16 am »
I wish someone produced just the kill switch.  Mine is pretty beat.
1975 CB750 K5
2007 Triumph Tiger
Offline mrbreeze
  • Not your average
« Reply #13 on: June 17, 2014, 09:07:46 pm »
The only wires that, if undersized, would be of issue would be in the right-hand switch, the START button might need a Relay Kit to prevent switch heating if halogen headlight is used. If stock headlight (Stanly or sealed-beam type) is used, no problems should crop up.
So I have a left hand control without the hi lo switch. Is this only for K0 thru K2 and maybe the early 73's or did they add the hi lo for all 73's?
MEMBER # 257
« Reply #14 on: June 17, 2014, 10:23:33 pm »
The K0-K2 had the OFF-LO-HI on the right side. The K3-K5 had the ON-OFF on the right (until partway through the K5, then it became like F0, see below) and the LO-HI on the left.
The F0/late K5 had no ON-OFF capability (I have also seen some K4 this way) on the right side, just the START button that turns off the headlight while electric starting. The Lo-Hi is on the left on these bikes, too.
Offline mrbreeze
  • Not your average
« Reply #15 on: June 17, 2014, 10:46:36 pm »
Oh boy!!! I think I'm confused now. Without talking about the headlight on/off switch......when did the hi lo switch appear on the left control? I have an old style with just the horn and turn sigs and a guy wants to buy it if it will work on his 72.
My bike is a 75 and I'm running Yami XS650 controls but my stock 75 had the headlight on/off on the right and hi lo on the left. I also know they changed after my year to where the headlite is always on. This is because of the law saying we had to run headlites during the daytime.
 So I need to know when the hi lo appeared on the left control. Thanks Mark.
MEMBER # 257
