Author Topic: CB360T Triple Tree Top Replacement  (Read 1051 times)
Offline theuplift
« on: December 23, 2012, 12:07:31 PM »
Hey Guys,
I have a 74CB360T with a broken top triple tree.  I read that the 81-84 CM400/450 is a direct replacement but to watch out as there are two different styles.  I am looking on eBay and wanted to know if anyone can verify that this is the correct model?
Also I see a bunch of early 80's CM250 triples on eBay.  Will those work??
Thanks,
Offline Pecantree
Re: CB360T Triple Tree Top Replacement
« Reply #1 on: December 23, 2012, 12:53:45 PM »
<edited> Assumed you had the clamp break and just looked at your picture.
Whats wrong with it?
Can't speak to the 400/450 replacement. Picked up a 360t replacement on ebay for $60 a couple years ago.
Be sure you put the washer between the clamp ears.
Also can recommend the Honda Twins forum.
http://www.hondatwins.net/forum/
When you find the answer repost it here. It will help some one down the line.
Good luck
Steve
« Last Edit: December 23, 2012, 12:57:36 PM by Pecantree »
Offline theuplift
« Reply #2 on: December 27, 2012, 02:55:17 PM »
the picture is of the CM450 triple tree that i found on ebay... i just wanted to confirm that it will swap out with my broken original...
Offline grcamna2
« Reply #3 on: January 09, 2013, 08:58:59 AM »
I know all the ones you've mentioned will fit the fork tubes and steering stem and will have the correct geometry to bolt right up as will the CB400F top triple clamp;you should inspect the pictures on ebay carefully to be sure they have the same instrument mounts as your early CB360T.
I know for a fact that the 1972' & 73' CB350K4 & K5 twins is a direct swap.  :)
Offline grcamna2
« Reply #4 on: January 16, 2013, 01:18:28 PM »
to theuplift,
                     How did it work out ?
