Author Topic: Inlet diameter 73 500 4 exhaust  (Read 1639 times)
jmanstuck
« on: July 13, 2006, 03:28:28 PM »
What is the inlet diameter of header? Thanks
Offline puppytrax
Re: Inlet diameter 73 500 4 exhaust
« Reply #1 on: July 13, 2006, 04:38:48 PM »
Are you asking for the actual inside diameter of the pipe?? I measure 1.050" on my #2 pipe for a 72 CB500 [73 is the same part #]. There is a coating of carbon on it, and the dia varies the farther in you go (more carbon buildup), but that's what I get...  8)
...stock 1972 CB500 '500 Four' undergoing re-assembly...
...Stock 1972 CL450 'Scrambler' also being re-assembled...
jmanstuck
« Reply #2 on: July 13, 2006, 04:57:59 PM »
Sorry should have been more clear. I need to know if buying a set of headers what size diameter the headers should be. Thanks
Offline puppytrax
« Reply #3 on: July 13, 2006, 06:09:10 PM »
The 4 new pipes I bought from Honda average 1.250" outside dia...which is also pretty much 32mm...
I measured the straight part of the pipe, under the foorpegs, as the bend at the head has variable dia no matter how I measure it...  ::)
