float height?...nope, just a small ruler...but you have to be very exact about what and where you measure from. The clear tube check might be more useful...mount your carbs in a vice or something so that they are level as they would be on your bike, rig a clear tube out of the drain in your float bowl, add gas, hold the clear tube alongside the float bowl, the level of the gas in tube shows you where the level of the gas in your bowls is, 3 or 4 mm below gasket should be ideal
![](http://i1309.photobucket.com/albums/s630/seanbarney41/bigbikeupdate037_zps525fa4fb.jpg)
this pic is on a cb350 twin though...idle screws? turn them in until they are gently seated counting the number of turns, now screw them all the way out, watch out for tiny spring, and possibly a tiny washer and/or o-ring(I can't remember what all is in those carbs), blow carb cleaner and air through the hole, replace all correct parts, screw them in until gently seated and then back them out the same/ correct number of turns, should be tweaked and adjusted when the bike is running via a plug reading
