Author Topic: Just another 71 CB750 K1 (After over a year, I finally got some 4 into 4 pipes!)  (Read 92432 times)
Offline edhaeuser
Great progress Ed.  ;D I love watching the engine build sections. That's the most exciting part for me.
I would agree with others that for the for cost of the part and how deep you are now you really might as well replace that cam chain!
IW
Thanks!  I installed a new heavy duty timing chain and have a new tensioner to go with it.  I guess I forgot to mention that.
Offline cheftuskey121
  • Super Newbie
nice work Ed, you've moved through it pretty quickly. youll be back to bike assembly in NO time. very excited for you :D
Offline edhaeuser
Quick question.
Can I use regular O-rings between the cylinder and head.  It appears the kit that I have only has o-rings for the later heads.  I cannot source viton seals locally, only the regular type.  I really want to get the top end done today, and this is holding me up.
Quick question.
The OEM ones were Buna N (durometer 65-75). Those are real common. Make sure the size is 2.5 x 12mm, not the undersized ones found in some gasket kits lately. I just bought some 2.5x12 in both Buna and Viton, if you can't find any there.
Offline edhaeuser
Thanks Hondaman!!
The extras that I have in my o-ring kit look like they could block the hole because they are so small.  I will try to find the Buna ones locally.  As always, you have the answer!!
Offline edhaeuser
Well, here goes another question.  Can I pull this metal cap on the cam chain tensioner to replace the seal underneath?  How would I pull it?  Or....do I need to find another cam chain tensioner.  I was hoping it was just an o-ring that I could pop out and replace, but it appears to be a small seal with a spring.  Live and learn  :-\
Offline edhaeuser
Here is another picture heavy update.
A few highlights as to what I have done with the engine:
case hole repair
new main bearings
new timing chain
new tensioner
honed the cylinders (still within new tolerance)
new rings
new wrist pins
recut valve seats
new valves
just ordered new stainless screw set for engine covers from James Spillane, a member here...stock style, not allen screws
some new engine case bolts and some I replated myself
Basically, a stock rebuild....nothing fancy as this is my first Honda engine
new tensioner from Cycle X, the old one was pretty chewed up
new wrist pins
cyclinders on
three angle valve seats
new valves from Cycle X
valve train back together
I polished up the valve cover....did I mention how much I dislike polishing...ugh.  It is not perfect, but it will do.
I was hoping to get the engine back in the frame before I have to leave for work again early next week, but I decided to order the new cover screws, rather than re-use the old ones.  So, I need to wait for the screws before I attach the valve cover.
« Last Edit: July 13, 2013, 09:36:44 PM by edhaeuser »
  • Super Newbie
Ed. wow. just wow.
Offline edhaeuser
Ed. wow. just wow.
Thanks Justin.  I'm not altogether satisfied with the polishing, but I need to draw the line somewhere.  My finish date looks to be more like next spring....a year longer than planned.  This whole engine rebuild is going very slowly.
It must be one of those things where the pictures hide the details/imperfections.  The polishing looks good.
Offline Tews19
  • I am no
Damn! Sick polishing! Seriously! I always like the bling on these engines!
1970 Honda CB750 survivor.
Offline edhaeuser
Thanks Guys!  I did walk into the garage this morning and thought.  dang, this does look alright.  I think I can live with this.  My wife says I am too much of a perfectionist sometimes....maybe I am.
Offline iron_worker
Ed,
The problem with doing meticulous work like engine painting/detailing/polishing is you're looking at it from a few inches away, maybe a foot or so. In reality, anyone looking at your bike (including yourself *most* of the time) will be looking at it from a few feet away. All the imperfections that seem HUGE to you at the time of the work really blend in with the overall bike when it's all together.
I know exactly how you feel! I'm starting to get over it a bit now that I've started riding. Once it's on the street, it will never be as clean as it once was! lol Road grime, bugs, water spots, a bit of chain oil, some spilled gas, etc etc.
The engine is looking really nice.  8) Keep up the good work.
IW
Offline edhaeuser
IW, you are right, of course.
I have one last small update before I head off to work for three weeks.  I turned on the Tour De France last night to watch yesterdays stage.  I figured I would get a little done on the bike while watching the race.  I decided I would do one of my favorite things. (not)   More polishing.  Except, this piece was really rough.  The stator cover had seen better days.
I started out with this scratched up, dented piece.  First, I block and hand sanded the deep scratches out with sand papaer.  I started with 80 grit because there were some reall nasty gouges.  From there I worked through 120, 400, 600, and 1000 grit.  I only used the 80 and 120 on the really bad areas.  After sanding, I used emery, tripoli, and finally white rouge buffing compounds with my bench grinder.  With each compound I went to progressively softer wheels.
The start...actually I guess that I had started a little sanding with 80 grit by this point.
I'm pretty sure this is after sanding out the scratches through 120 grit.  I did not get every scratch out, but most are gone.
It's a dirty job, but someones got to do it.
I'm pretty sure this is after wet sanding 400, 600, and 1000
First cut with emery compound...before cleaning for the next step.
after the tripoli compound.  All cleaned up and ready for the white rouge.
After white rouge....all done, except for maybe a little hand polishing if I really feel like it.
I don't know if this is the right way to polish....I think I got this technique off the Caswell site.  Once again, not perfect, but pretty good.  It seems I always have a few errant sanding scratches that I don't get out.  Of course, considering that I had to use 80 grit to get the gouges out, it looks good.  There were scratches all over this thing.
Damn fine job.
Offline Viktor.J
  • Breaking in the forum
Hey ed !
Great work with The polishing, your method and results are simular to mine. But do you have Any plan to preserve this newly polished finish ?
I was thinking on wax but don't know if there's any wax that can stand the heat :)
Please ! Take a look and give me feedback in my project thread, its much needed :)
http://forums.sohc4.net/index.php?topic=112745.0
Honda CB750 K2
Offline edhaeuser
Hey ed !
Your guess is as good as mine on that.  I will probably wax it and see how that goes.  I polished up my Triumph covers a few years ago, and they are holding up fairly well.
Offline Viktor.J
Hey ed !
When you do it would be great if you could provide which wax & method, that you'll use. I've been riding with my polished covers a few months now and they allready lost quite a lot glow, so Ill probably end upp hand polishing a bit beafore I wax...
Honda CB750 K2
Hey Ed - motor looks great as well as the stator cover. I've got an old one, mind if I send it over for a polish job? Ha!
Where have you been working?
Offline edhaeuser
Steve, I only polish because I'm too cheap to pay someone else to do it :-)   I've been working in Europe this month.  I enjoy the work, but ready to be home.
Offline edhaeuser
Should I remove my oil pan and pump to re-install my engine in the frame?  Thanks.
I think I will, it seems like there would be a lot more wiggle room.
« Last Edit: August 12, 2013, 02:01:50 PM by edhaeuser »
You dont have to remove the pan, safer for the engine actually.
Exhaust studs if you have them and greaat trick is to grind down the flange of the right front mount on the frame to make it easier to install.
Offline edhaeuser
Thanks for your reply.  I had already ground down the flange on the frame.   Per your suggestion I tried to remove the exhaust spiggots.  I figured I would remove the three on the left side...leaving the one on the far right.  (it didn't seem like that one would interfere with anything)  Well, I got the first two loose with an impact screwdriver....not so lucky on the third one, one of the screws twisted off in the head.  I guess I will be doing some carefull drilling to try to get that broken screw out.  Insert expletive here! My wife said "I knew you had screws loose in your head, but I didn't know any were broken"
Sorry! :)
I was lucky, my bolts came out just fine.
Offline edhaeuser
Sorry! :)
No worries, it's not your fault.  I appreciate the input!
