Author Topic: Engine Swap  (Read 2141 times)
Offline Big C
Engine Swap
« on: January 06, 2013, 12:28:47 PM »
I am attempting to bring a '76 750A back to life. The bike has 4,000 miles on the clock and I was told that it had been in storage for 30 years. Not much wear on anything, original tires, original gas in the tank (nice!) and the engine was frozen. I figured that I could sort that out, but what a mess! The pistons in cylinders 1 and 4 are all the way down, and cylinder 1 is badly rusted with a 2" deep pile of rust flakes and crud in it. I am trying to decide whether to either attempt to repair it, part it out, or buy a different engine.
Will a standard 750 engine fit the frame? I would welcome your thoughts on this project. Thanks!
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: Engine Swap
« Reply #1 on: January 06, 2013, 12:41:56 PM »
Can you - or have you tried to pull the cylinder?  You can replace the cylinder/pistons without removing the engine . . . .
I believe that a standard 750 can be fitted - maybe someone else will chime in . . . .
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline Big C
Re: Engine Swap
« Reply #2 on: January 06, 2013, 01:35:07 PM »
I haven't been able to get the cylinders loose yet. The cylinder assembly seems to be pretty well stuck. I have soaked the bores for several weeks with oil. Would you suggest that I bang on the pistons with a chunk of wood? I wouldn't be too concerned about damaging the pistons or cylinders, just don't want to damage the con rods.
  • Moderator
  • Moderator
Re: Engine Swap
« Reply #4 on: January 07, 2013, 05:00:22 PM »
Take the advise of Prospect in that thread and remove the bottom end and disconnect the rods so that you don't do any damage to the bearings.
A five speed motor MIGHT fit but the earlier K model chain alignment might be out a bit, the later F model should be ok.
Sam. ;)
Offline Big C
Re: Engine Swap
« Reply #5 on: January 08, 2013, 08:21:47 AM »
I will take your advice regarding the bottom end. Thanks!
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
Re: Engine Swap
« Reply #6 on: January 09, 2013, 03:41:08 AM »
Big C
PM sent
GL!
Mike
