Author Topic: Need Help: Adapting Pods  (Read 1121 times)
Offline Zeke
« on: July 13, 2006, 10:04:38 PM »
Guys:
It turns out that K&N doesn't have pods that work with my 1980 CB650C.  They have the ones for 81/82 mislabeled.
The universal ones don't appear to have a long enough "throat" to clear the choke arm.
The 46mm diameter has a 5/8" long throat, and I need about an inch for clearance.
What have you geniuses done to adapt pods in situations like this?
Thanks.
Offline cb650
Re: Need Help: Adapting Pods
« Reply #1 on: July 14, 2006, 04:23:22 AM »
Think I posted that once.   I made some aluminum sleeves to set the middle 2 out to clear the arm.
Never was happy with it so sold the filters and am leaving stock box on with k&n filter in it.
                            Terry
Offline jdpas29
  • my bike is 100% sandcast!!
    • My band = white bread
« Reply #2 on: July 14, 2006, 05:28:14 AM »
i had to take the rubber boot nearest the choke arm and turn it diagonal on the metal intake housing where it actually came back off the carb at about a 30 degree angle.  this gave just enough clearance for the choke arm to move and for the boot to still seal good.  try it.   you'll never see that spot on a inline 4 anyway.
cars are gay.
Offline Zeke
« Reply #3 on: July 14, 2006, 07:18:46 AM »
Terry
Hi Terry:
Was it your adapter arrangement you were unhappy with, or was it just too difficult to tune the pods?
Thanks,
Zeke
Offline Zeke
« Reply #4 on: July 14, 2006, 07:21:22 AM »
Hey JD:
So the pods that you were using had an angle on it?
Were you able to get the bike dialed in with the pods?
Thanks,
Todd
Offline Zeke
« Reply #5 on: July 14, 2006, 08:09:52 PM »
Bump
Offline Frankenkit
  • Industrial Strength
« Reply #6 on: May 01, 2008, 08:40:37 AM »
Thanks for posting this. Just bumping it.  I was thinking about pods for my '80 650c...
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #7 on: May 01, 2008, 08:45:24 AM »
I had to make universal pods fit on '79 CB650 carbs since the PO had chucked the air box.  I cut down the plastic choke lever so that it fits between the 2 center pods and cut in a new slot for the cable.  We'll see how long it lasts.  If it breaks, I figure I could make a slim lever out of aluminum.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
Offline cb650
« Reply #8 on: May 01, 2008, 04:29:08 PM »
I made short alum tubes to clamp on 2&3 carbs and then put filters on them.   Never had trouble with jetting.
