Author Topic: powdercoating brake discs  (Read 1871 times)
Offline mazingerzeca
« on: January 05, 2013, 06:33:39 AM »
Hello all.
I would like to paint the inner part of my brake discs (CB750). Given that I am going to bring some parts to the powdercoater, I wonder if I could include the brake discs, but I'm afraid that they could distorto due to the powdercoating oven temperature. Is the temperature safe for these discs? Thank you.
Offline purf_man
Re: powdercoating brake discs
« Reply #1 on: January 05, 2013, 06:40:54 AM »
totally safe.
I just had mine done (getting them next week)
1975 CB550
1978 RD400
« Reply #2 on: January 05, 2013, 06:46:21 AM »
totally safe.
Me too.
« Reply #3 on: January 05, 2013, 06:51:13 AM »
Thanks for the replies. I will powdercoat them.
« Reply #4 on: January 05, 2013, 07:11:56 AM »
When my guy masked off the braking surface, he left the circumferential edge. It got coated for a nice effect.
Offline RSchaefer
« Reply #5 on: January 05, 2013, 07:31:27 AM »
I had been considering this!  Looks like from the one picture you went ahead and coated the pin/bolt heads around the inner ring as opposed to masking them off as well.  I was looking at the stock look and the masking effort would be substantial unless you forgot about the bolt heads.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #6 on: January 05, 2013, 08:01:48 AM »
Hmm, it never even occurred to me. The powdercoater did it that way and I didn't offer an opinion.
I think he taped it, then ran a razor blade around the easiest border.
Offline Harsh
  • 74 CB750 and two 72 CB350's
« Reply #7 on: January 06, 2013, 05:18:41 PM »
That is how I did mine.
« Reply #8 on: January 06, 2013, 06:09:00 PM »
That's some crazy drilling, MC.  I really like the coating on the edges.
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #9 on: January 06, 2013, 06:28:14 PM »
Tip from another pro. (not this guy, just useful information) Because of the inconsistency, of powder coat. If the inside of the disk rim (look below) is powder coated. When its bolted to the wheel, it might not be parallel with the wheel. One guy was telling me that when he was test driving it, when braking it would be inconsistent, it would shutter to a stop, not wile riding, just braking. Took the wheel off left the disks on, and brought it to his balancing station, spun the wheel and the disk wobbled. Not because of improper balance, or lose bolts but because of powder added thickness in between the rear of the disk and the hub. ".003" of and inch of powder  coat thickness transferred to .03 or so of wobble on the outer disk edge.
Keep riding, it looks good, just wanted to share my knowledge.
Current ride: 78' Cb750F
Offline RSchaefer
« Reply #10 on: January 06, 2013, 06:37:38 PM »
Very good point I think!!
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #11 on: January 06, 2013, 06:45:44 PM »
Also, don't powder-coat the inside of the center hole, as it may not allow the disc to fit on the wheel hub.
« Reply #12 on: January 06, 2013, 07:03:17 PM »
All good points!   ;D
« Reply #13 on: January 07, 2013, 12:57:19 AM »
Had mine done too. He even coated the outside edge!
Offline lucky
« Reply #14 on: January 07, 2013, 06:37:40 AM »
Do you mean the part the brake pad is in contact with??
Offline lucky
« Reply #15 on: January 07, 2013, 06:38:00 AM »
Offline RSchaefer
« Reply #16 on: January 07, 2013, 06:42:07 AM »
No I think he means the outside perimeter edge as in the original MCRider picture
'76 GL1000 LTD
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
« Reply #17 on: January 07, 2013, 01:16:14 PM »
Geez Lucky no one is THAT bad  ;) Rich is correct, the 'edge' not the surface. Guess he thought that'd be cool looking?
