Author Topic: Engine Case Blt replacement. To flange, or not to flange that is the question...  (Read 663 times)
Offline brandEn
I need new upper and lower engine crankcase bolts. They are flange bolts and they are available from Honda but they want Honda Prices. I can get zinc plated, class 10.9, hex bolts and washers for half the price at Bolt Depot. In my usual way of over thinking everything I am wondering, is there any reason I may have overlooked why this can't be done? Is there some crazy reason these need to be Honda Flange bolts?
;D
Offline Old Scrambler
If the threads are IDENTICAL.......go for it and have a free beer 8)
If you do, I would retorque after a heat cycle ;)
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Fritz
The flanges act as spring washers and prevent the bolt from becoming loose.
If you use non-flanged bolts, chances are that they would not hold the torque over time, so you'd better use spring washers along with them...
(source: Honda Common Service Manual)
1976 CB550F
Offline brandEn
Awesome.
Thanks for that picture.
« Last Edit: January 10, 2013, 04:11:32 PM by brandEn »
Offline MoMo
  • Ride like you're invisible
thanks for that info-I learned something today ;)...Larry
