Author Topic: Which CB750 SOHC had the longest gas tank?  (Read 1179 times)
Offline Stoli
« on: October 02, 2013, 07:19:33 PM »
I assume it was one of the F models, but which one? Is there any difference between the F1, F2 and F3 tanks?
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline RSchaefer
Re: Which CB750 SOHC had the longest gas tank?
« Reply #1 on: October 03, 2013, 07:26:32 AM »
F0 thru F3, same tank, two different gas spigot sizes, but same tank otherwise.
'66 CB77, 305 Superhawk (Project Bike)
'72 CL 175, (Project Bike)
'75 CB750F (Project Bike, Complete)
'05 GL1800 ABS Black Cherry (Current Ride)
'87 GL1200 Wineberry Aspencade
'83 GL1100 Wineberry Aspencade
'76 GL1000 LTD
'75 GL1000 Turquoise
'69 Honda 750cc Gold
'67 Honda 305 Dream Black
'63 Honda S90 Black
'61 Honda 50 Red
GWRRA #000008
VJMC Member
Wobbly
« Reply #2 on: October 03, 2013, 07:48:05 AM »
I believe, the K7/K8 tanks are the same length as the F2/F3 tanks. They just don't look it because they are wider.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: October 03, 2013, 07:57:11 AM »
Assuming the front mounting points on the tanks are set back from the front leading edge by the same amount on both tanks, the F2 tank is definitely longer than the K7. With the K7 tank fitted on my F2, there is a gap of about an inch twixt tank and seat. The front and rear mounting positions on both tanks however are the same.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Elan
    • Vital Motor Parts
« Reply #4 on: October 03, 2013, 12:18:49 PM »
answer: the CR750  ;)  ;D ;D ;D
76 750k
Offline Stoli
« Reply #5 on: October 03, 2013, 12:42:57 PM »
Actually, that is exactly the tank I am looking for minus the breather and the reservoir on the bottom aft. And I'd rather have the filler cap centered. Is that too much to ask?  ??? I don't want a fiberglass one however and the aluminum ones are a little more than I wanted to spend. Still considering it though.
My Project Threads:
Offline cheftuskey121
  • Super Newbie
« Reply #6 on: October 03, 2013, 04:19:29 PM »
when you find it let me know, thats the kind of tank I want for my next project. namely something like this.
CB750F Cafe Racer Raw
« Reply #7 on: October 03, 2013, 08:21:43 PM »
The longest tanks i have seen were stretched stockers on double engine 750,s
