Author Topic: 1977/1978 CB's are cool 2!  (Read 95353 times)
Re: 1977/1978 CB's are cool 2!
« Reply #300 on: June 13, 2014, 09:59:03 PM »
don't think I got my f3 in here yet...
Looks F'n great, SB.
looks can be decieving...I am not used to my Honda's breaking down every other week...I will get it sorted though
Offline Prez1967
  • Adding lightness...
« Reply #301 on: June 14, 2014, 03:18:56 AM »
Im really starting to dig the F's wheels and seat/tank combo! Would all those oarts be bolt ons for a K bike??
Offline AintNoEasyWay
« Reply #302 on: June 14, 2014, 04:53:18 AM »
Stopping in to say 'hello' to everybody. Should be great riding weather in Tennessee today.
« Reply #303 on: June 14, 2014, 05:07:10 AM »
I can attest for wheels, I will be using them in my K3F - see my signature. The rear wheel needs F swingarm to accomodate the brake disc and extended rear shock mount on the left.
The front you could go with the whole fork and get dual brake setup, it bolts right in K triple tree.
You could even find F wheels for tubeless tires, from like 1980 DOHC or so. I know I will go tubeless once the K3F is on the road.
« Last Edit: June 14, 2014, 05:09:19 AM by 70CB750 »
« Reply #304 on: June 14, 2014, 05:12:55 AM »
what year k bike? wheels will not "bolt on" to a k bike but the entire front fork assembly will.  Same in the back, easiest way is to use the whole swingarm although I think there are some mods that have to be done?.  Tank fits all years.  Seat will not fit 69-76 k's without custom work.  I don't know about f seat fitment on 77-78 k bikes.  70CB750 has the details and has posted while I was typing.
Offline lucky
« Reply #305 on: June 14, 2014, 09:20:30 AM »
"Black Sheep"?????!!!!! Are you kidding?
The 77-78 CB750 had the most improvements of all of the Honda CB750 SOHC'sw.
I am not going to list them all .
21 changes in all.
Some of the changes:
Bigger valves.
Redesigned clutch.
More cooling fins on the engine.
Wider cam chain galley.
Better cam chain.
Better oil drain down system.
More cooling fins on the oil filter housing.
Higher 4th and 5th gear.
The only thing I did not like is the carbs. The EPA ruined those.
I am not against  a cleaner environment but the way they forced the changes it was a mess.
The 1969-70 CB750 carbs are still the best of all of the carbs.
That is WHY the price for them is very high.
The float bowls removed with a simple clip. No Screws.
You could remove all of the slides while the carbs were on the motorcycle.
No lifter arms or lifter shafts. Huge weight difference.
The idle screws had marks indicating when they were fully closed.
All jets could be removed while the carbs were on the bike.
All mixture screws were easily accessible.
The float bowl drain screws were aluminum as were the vacuum port screws,so corrosion potential was reduced.
One throttle cable.
They produced the most power.
!977-78 Engine-1969 carbs Killer set up!
« Last Edit: June 14, 2014, 09:26:18 AM by lucky »
    • http://forums.sohc4.net/index.php?PHPSESSID=dl2l7n82rsamc7nvrck8bhbq81&/topic,60973.0.html
« Reply #306 on: June 14, 2014, 11:18:22 AM »
the black engines eats valve guides...they are just  to hot..in cam degreds...all now this...or is it a myth
Offline lucky
« Reply #307 on: June 14, 2014, 02:21:06 PM »
It was the valve stem keepers that caused the problem.
Cycle-X has a solution.
« Reply #308 on: June 15, 2014, 03:41:09 PM »
It's all right here..
http://forums.sohc4.net/index.php?topic=10540.0
fendersrule
« Reply #309 on: June 15, 2014, 03:48:47 PM »
My 78' won third place today at a VJMC rally. Heed that non-believers!
Offline Stoli
« Reply #310 on: September 20, 2014, 08:16:10 PM »
New entry for the  8) club. Not sure if it qualifies but it has a '77 tank and headers and shocks from a K8. Everything else is from earlier years. Used what I had.
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
Offline Mr Freeze
« Reply #311 on: September 21, 2014, 06:14:38 AM »
My ride. All 1978. Supersport gas tank and front end, K motor and frame. Custom seat, headlight setup, wiring. etc.
Offline dlhoulton
« Reply #312 on: September 21, 2014, 06:43:04 AM »
My recently completed resto/mod 1977 CB750F. Love the F's.
Offline BPellerine
« Reply #313 on: September 21, 2014, 04:40:57 PM »
I guess if everyone is doing it ,here is my 78k.bill
1978 CB 750K ard and webers
another anfob
« Reply #314 on: September 21, 2014, 05:09:19 PM »
'77 CB550F
Offline Juan1
« Reply #315 on: April 17, 2015, 10:35:49 PM »
Here's mine.  The headlight and gauges were not restored and the tank could use a bit of work, but she rides well because of the info on this forum.
« Reply #316 on: April 18, 2015, 12:19:03 AM »
I might regret in the future but K7, F1 and F2 can be found in very good shape here for not that much money.
It is something very special with K0-K6 that cost double, especially K0 that cost 3x.  Original 4-4 for the K7 cost about 1/4 of the K0-K6 (HM300/341)
I have seen very nice F2's with small modifications.
« Reply #317 on: April 18, 2015, 07:30:12 AM »
Nice job putting that bike back on the road, Juan.
« Reply #318 on: April 18, 2015, 07:41:22 AM »
nicely done, Juan  8)
« Reply #319 on: April 18, 2015, 08:51:23 AM »
Great job! Reliable bike is always pretty.
Offline CB750R
  • 77 CB750F
« Reply #320 on: April 19, 2015, 08:55:02 AM »
Wow, hats off to an amazingly clean F2! That thing is beautiful.
Offline atm cycles
« Reply #321 on: April 19, 2015, 09:11:39 AM »
I've had several k and f stock and not. This one was my favorite
Offline atm cycles
« Reply #322 on: April 19, 2015, 09:19:55 AM »
Love f tanks
Offline toytuff
  • "watching the pinheads"
« Reply #323 on: April 20, 2015, 11:24:07 AM »
The thread is still alive!
 8)
tt
Offline mkoski
« Reply #324 on: April 20, 2015, 12:47:40 PM »
