Author Topic: Cam Chain Replacement CB750 SOHC  (Read 2828 times)
Offline stevesearles
« on: February 05, 2013, 01:57:38 PM »
Do you have to pull the motor to replace the cam chain using the master link method on a CB750 SOHC??
Offline goldarrow
  • one day, i'll be an
Re: Cam Chain Replacement CB750 SOHC
« Reply #1 on: February 05, 2013, 02:14:23 PM »
Yes you do
CB550 K0
« Reply #2 on: February 05, 2013, 02:25:12 PM »
Yes you do
Yes. The cam cover will only come up about 1/2 in or so, while its in the frame.
Unless you or a PO cut the frame rails out which was and is a popular modification. Replacing them with a bolt in variety.
Offline 74750k4
« Reply #3 on: February 05, 2013, 02:46:08 PM »
Heartbreaking isn't it? I was in a bad mood for days when I realized that. Once you have pulled the engine a few times though, it becomes more routine :)
« Reply #4 on: February 05, 2013, 06:05:53 PM »
Yes, heartbreaking, upset, pissed and swearing at the Japanese engineers again that had too much saki. Great machine but they never think of the mechanics who have to service the machines. I am disappointed in Honda. Can you tell me more about the cutting of the frame rail. Is there a part readily available to just bolt back in? Let me know please.  Another good reason to restore my Kaw Z1900 instead of a Honda 750. Thanks guys.
Offline Thousandson
  • Ride, Fix, Repeat
« Reply #5 on: February 05, 2013, 06:17:20 PM »
You cut the two frame rails under the center spine and install (image below) suds for easier engine removal. But you need to cut some metal and weld the suds to the frame.
Should look like this when your done.
Current ride: 78' Cb750F
Offline Kevin D
  • SE Michigan
« Reply #6 on: February 06, 2013, 03:24:26 AM »
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
