Author Topic: 78 cb 750k carb question  (Read 1617 times)
Offline bultaco59
« on: February 01, 2013, 06:34:52 AM »
Hello gentlmen, I know Im asking alot of questions,this being my first sohc 4
Ok heres the deal, I gots carb apart, and there ready to soak, when I took them
apart, there is this big diafram, with linkage that connects to the main shaft
with hoses that connect to the carb, and to this switch of some sort that has
electircal connections (2 wires)that plug somewhere on the wiring harness.
1. What the hell is it ? 2. Do I need this. on reasssembly I would like to leave
all of this off, I m guessing its smog stuff. has anybody seen this stuff. I sorry
theres no pictures, but Im at work.
Thank You
Bob in Burbank
Re: 78 cb 750k carb question
« Reply #1 on: February 01, 2013, 06:55:21 AM »
apart, there is this big diaframACCEL PUMP DIAPHRAGM, with linkage that connects to the main shaft ACCEL PUMP SHAFT with hoses that connect to the carb, and to this switch of some sort that has
electircal connections (2 wires)that plug somewhere on the wiring harness.  NO CLUE
Thank You
Bob in Burbank
Yes, you'll need the accel pump components.  they help 'prime' the throats of the carbs with fuel for easier starts.   The diaphragm cup fills with gas, and with the first 1/4 throttle movement shoots the fuel into the accel pump system.  the fuel travels through passages and tubes(see below, pink tubes w brass inserts) in between carbs, and out these small brass injector posts which can be seen in the photos below.  they can create a good spray of gas to get you going from a full stop.  as for the rest of the 'electrical' stuff....i got nothing  ;D
« Last Edit: February 01, 2013, 06:57:05 AM by flybox1 »
Offline toytuff
  • "watching the pinheads"
« Reply #2 on: February 01, 2013, 06:55:57 AM »
Where in the pictures?
tt
Offline bultaco59
« Reply #3 on: February 01, 2013, 07:40:31 AM »
Its not in the pictures, it is also not the acel pump that is on carb, this is a whole
seperate unit that sits on top of the carbs. it appears to be a diafram like said
coming out of the bottom a arm, that does not push the main shaft, it is accually connected to a arm on tha main shaft. it is about 2 in in dia. the other component
look like a air sw like on a smog system (sensor?)
« Reply #4 on: February 01, 2013, 07:52:50 AM »
post pictures when you can..
Offline bultaco59
« Reply #5 on: February 01, 2013, 07:57:06 AM »
Ok when I get home.
Offline stewonepot
« Reply #6 on: February 01, 2013, 08:16:03 AM »
Hi All,
Is possible his carbs come from an auto?
Regards Stew.
Offline mrrch
« Reply #7 on: February 01, 2013, 08:25:42 AM »
The Automatics have a solenoid on the carbs.
my build
Offline stewonepot
« Reply #8 on: February 01, 2013, 08:39:23 AM »
Which would explain the wires maybe?
regards Stew
« Reply #9 on: February 01, 2013, 10:22:04 AM »
« Reply #10 on: February 01, 2013, 05:57:58 PM »
 Ha...we've got 2 threads going on here.
Get rid of those 750A carbs, and find some PD's.
Might want to contact member sohcdigger for a set...you'll be happy later...
Offline toytuff
« Reply #11 on: February 01, 2013, 07:16:33 PM »
AaHa!
tt
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: February 02, 2013, 06:39:07 AM »
I'll lock this duplicate thread.  Please use the other one for further discussion on this topic.
