Author Topic: Laser cut gaskets or PDF file of them?  (Read 4125 times)
Offline ncstatecamp
« on: February 01, 2013, 06:40:57 PM »
Has anyone on here used a laser cutter to cut their own gaskets?
Anybody got digital files of the gaskets for a 750?
Re: Laser cut gaskets or PDF file of them?
« Reply #1 on: February 01, 2013, 10:05:08 PM »
hey thats a good idea,i have a mate whos a printer,he has a sticker cutting machine,you just draw what you want in some program and its cut out,im going to ask him if i can try putting gasket paper in the cutter,i could scan a gasket?
Offline 74750k4
« Reply #2 on: February 01, 2013, 10:57:30 PM »
Here's the oil pump, and tensioner gasket in pdf.
Offline 74750k4
« Reply #3 on: February 01, 2013, 10:59:44 PM »
...and again in jpg
Offline ncstatecamp
« Reply #4 on: February 01, 2013, 11:59:20 PM »
anybody know if a 76 750f would have the same gaskets? I did find those scans
http://www.dotheton.com/forum/index.php?topic=44761.0
« Reply #5 on: February 02, 2013, 04:49:57 AM »
I seem to remember that our moderater,the esteemed Bob Wessner had some life size templates of some kind, of gaskets that could be printed out then layed and taped out on gasket material and then cut out old school with an exacto or craft knife. Bob ?? Us old guys are crafty not techie  :D
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: February 02, 2013, 07:35:22 AM »
I did something similar with some of the gaskets for my Enfield. I scanned them so I had full size images, then I would use those to trace on to gasket material and cut out with scissors and a razor knife.
Offline ncstatecamp
« Reply #7 on: February 02, 2013, 11:50:49 AM »
Since I've got access to a laser cutter and can make a bunch quick with a lil up front work I wanna see if this works well. If those 750f will work on a k then I can do it. Anybody got a pro/con to different types of gasket material?
« Last Edit: February 02, 2013, 12:38:16 PM by ncstatecamp »
« Reply #8 on: February 02, 2013, 12:51:21 PM »
the thickness is important on most of them aswell.
Offline ncstatecamp
« Reply #9 on: February 02, 2013, 01:10:03 PM »
All of the outer covers seem to be the same thickness, any difference between those and the head gaskets?
« Reply #10 on: February 02, 2013, 01:20:29 PM »
id prefer to use a proper head gasket.
Offline ncstatecamp
« Reply #11 on: February 02, 2013, 01:25:42 PM »
Not sure what that means. I don't need one now just thinking ahead.
Offline Bru-tom
« Reply #12 on: February 02, 2013, 01:33:16 PM »
what he means is, is that you shouldn't use normal gasket "maker" sheet to use as a head gasket.
Offline ncstatecamp
« Reply #13 on: February 02, 2013, 01:37:21 PM »
Ah ok. So metal type then? Or what?
Offline Bru-tom
« Reply #14 on: February 02, 2013, 01:42:28 PM »
i wonder if one could copy the head gasket shape in CAD, have it laser-cut out of the suitable material and use a thin piece of gasket maker either side, like a sandwich. then it could be reusable?
Offline ncstatecamp
« Reply #15 on: February 02, 2013, 01:54:18 PM »
My plan was to make a cadd file from the scans and laser cut them from the fiber or rubber material. To cut metal it'd have to be a pretty substantial laser cutter. I've got an access a Cnc plasma that could do it though. What's a typical head gasket made of?
« Reply #16 on: February 02, 2013, 03:13:13 PM »
how will you replicate the steel ring in the head gasket?
Offline ncstatecamp
« Reply #17 on: February 02, 2013, 03:15:37 PM »
That's what I was asking before on what material a head gaskets made of. Ive never dealt with a head gasket before. Is the whole thing a steel gasket or is it combination of materials?
« Reply #18 on: February 02, 2013, 03:43:38 PM »
the factory type is a combination,you can get full copper and steel ones for racing/hipo applications.
heres a factory type.
« Last Edit: February 02, 2013, 03:49:17 PM by dave500 »
Offline ncstatecamp
« Reply #19 on: February 02, 2013, 07:06:18 PM »
Around the main holes, is it thicker or is it just the angle? Think it would be feasible to Cnc plasma cut one from some sheet steel?
« Reply #20 on: February 02, 2013, 11:09:15 PM »
the proper head gasket isnt expensive,itll cost you more to cut a steel or copper one,it has to seal oil pressure galleries aswell.
Offline ncstatecamp
« Reply #21 on: February 03, 2013, 01:37:12 AM »
are you saying itd be more expensive to buy a sheet of what ever gauge steel then buy one? Where I work has a bunch of toys that can get this done easy...
« Reply #22 on: February 03, 2013, 06:13:29 AM »
Think on something that critical like a head gasket I would have to go with something thats been out there and proven to work well from a major manufacturer. Sidecover gaskets etc. have less technical issues as far as performance.
Offline 74750k4
« Reply #23 on: February 03, 2013, 09:26:39 AM »
Yes, but it's much more fun watching someone re-invent the head gasket manufacturing process where they work! Especially for 1, or 2 gaskets!!! :)
Management will be thrilled with you! :)
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #24 on: February 03, 2013, 10:15:18 AM »
Found this on Wiki:  Head gaskets are more than just a "gasket".
MLS or Multiple Layers Steel – Most modern head engines are produced with MLS gaskets. These typically consist of three layers of steel. The contact faces are usually coated with a rubber-like coating such as Viton that adheres to the cylinder block and cylinder head while the thicker center layer is left bare.
Solid copper – a solid sheet of copper, and typically requires special machining called 'o-ringing' that places a piece of wire around the circumference of the cylinder to bite into the copper. When this is performed copper gaskets are extremely durable. Recently companies have started producing copper gaskets with integral sealing wires permitting their retrofit into engines without the removal of the engine block for machine work.
Composite – an older technology. Typically these are made from asbestos or graphite but are more prone to blowouts than newer gaskets. Asbestos gaskets are becoming increasingly rare due to health concerns.
Elastomeric – a gasket type used by Rover on their K Series engines. It utilised a steel core plate with molded in place silicon rubber beads to seal oil and coolant passages. The bores were sealed by rolled steel fire rings in a more conventional manner. The idea behind the gasket design was to produce a production version of the technology used in F1 engines at the time. The original application of the gasket on the smaller versions of the K Series was very successful. However, an engine redesign resulted in persistent problems with the design – the joint interface became unstable and the gasket could not cope.
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
