Author Topic: Laser cut gaskets or PDF file of them?  (Read 4124 times)
Offline 74750k4
Re: Laser cut gaskets or PDF file of them?
« Reply #25 on: February 03, 2013, 10:20:23 AM »
Piece of Cake! :)
« Reply #26 on: February 03, 2013, 10:34:14 AM »
Honda had trouble getting it right,maybe you will have better luck. If I were in your position I would only consider copper, after you get over the price for a half sheet. Who is programming the cutter..areyou sure the company is OK with that?.. Not a small job..
Offline ncstatecamp
« Reply #27 on: February 03, 2013, 01:57:01 PM »
Alright alright I've got the picture no need to humiliate me more. I learned a lot so thanks. I'll just stick to doing the cover gaskets.
As a side note though the programming for this stuff really isn't that difficult.
« Reply #28 on: February 03, 2013, 04:13:31 PM »
The head gaskets are. In several versions, due to differrences in oil sealing o-rings and collar changes. If you make gaskets , maybe sell some on here. Thanks
Offline ncstatecamp
« Reply #29 on: February 03, 2013, 04:38:27 PM »
Yeah I was thinking about selling em. I only got it doesn't matter on material type. Is there a preference around here?
Offline 74750k4
« Reply #30 on: February 03, 2013, 06:05:45 PM »
Yes...
Viton flouroelastomer...  and the stuff ain't cheap!
http://www.mcmaster.com/#standard-rubber-sheets/=lbp16k
« Reply #31 on: February 03, 2013, 09:18:09 PM »
Think the last time I bought an OEM gasket,summer before last, from my local Honda shop for my 750 left side shift cover,which is pretty large, was $9.00 and some change with no shipping.Guess that would be the price point you may be competing with.
« Reply #32 on: February 03, 2013, 11:23:42 PM »
if you can make your own bottom end gaskets thatll be a saving enough,my mates cutter has a tiny blade,hes not too keen on me trying anything but sticker material in it,,fair enough,like everyone ive done the old cornflakes box clutch cover gaskets that work perfectly well.
« Last Edit: February 03, 2013, 11:25:22 PM by dave500 »
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #33 on: February 04, 2013, 08:04:31 AM »
ncstatecamp If you come up with cover gaskets at a reasonable price I'll be in.  Paid $15 for an oil cover gasket at the local shop over a year ago and I'm still pissed about that. If you can figure out how to cut tank decals at a reasonable price,you might have your boss asking you for a job. Don't let the naysayers slow you down.
GL!
Mike
Offline ncstatecamp
« Reply #34 on: February 04, 2013, 11:48:24 AM »
GL!
Mike
Oil cover? Do you mean the pan? My plan right now is all the side gaskets, clutch, alternator, and associated top covers. Pretty much everything flat.
I was actually just thinking about the stencils from stickers, I can tune a laser cutter to cut through 1 layer of paper and no more. Which tank decals are you talking about?
« Reply #35 on: February 05, 2013, 03:59:24 AM »
You can buy - at least this side of the puddle - gasket paper in some car parts stores.  Done it for my jeep before.
Offline ncstatecamp
« Reply #36 on: February 07, 2013, 01:43:18 PM »
OK so those that I originally posted before are not a match. Does anybody have pack lying around they could scan so I could get a file of em? or know a way I could the shapes unnecessary digitally. Its for a 750k
Offline bruzer59
  • 1977 CB 750F
« Reply #37 on: February 07, 2013, 01:58:20 PM »
I HAVE GASKETS SCANED FOR CB750   OIL PAN  CLUTCH   TRANS COVERS
Offline ncstatecamp
« Reply #38 on: February 07, 2013, 02:00:09 PM »
I HAVE CB750 OIL PAN , CLUTCH , TRANS COVER GASKETS ON FILE  IF YOU NEED..
That and anything else. Wasn't planning on doing the oil pan but I'll be good to have. I'm doing my alternator cover, clutch cover, shifter, valve cover and the top covers that go over those.
Offline bruzer59
  • 1977 CB 750F
« Reply #39 on: February 07, 2013, 02:14:27 PM »
PM ME  OR EMAIL ME & I WILL SEND OUT THE PDF FILE OF THE GASKETS
Offline ncstatecamp
« Reply #40 on: February 11, 2013, 12:32:44 AM »
The scans I got are alright but a bit fuzzy. Could I just scan each cover and get a profile that way?
