Author Topic: is there an easy way to check valve clearances  (Read 768 times)
Offline Scott
  • 72 CB750
« on: February 01, 2013, 10:02:09 PM »
Hello
I have a CB750 72.  I want to check the valve clearances but it looks like a pain in the arse.  Do you guys just bend the end of the feeler gauge and try to get in there or can you lift the valve cover and get to them that way or just leave it until the engine comes out one day
Thanks for any tips and help
Scott
Re: is there an easy way to check valve clearances
« Reply #1 on: February 01, 2013, 10:16:38 PM »
 The .002. And .003 feelers are very flexible they fit in easily..
« Reply #2 on: February 01, 2013, 11:30:44 PM »
get a fine wet stone and sort of make a slight ramp both sides of the feeler tip so they slide in easier.
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: February 02, 2013, 12:03:10 AM »
I got a set of .002 and .003 feeler gauges that have a 45 degree bend from the parts unlimited catalog at the local motorcycle shop.
Motion Pro, part #P552, less than $6.00
Here's what it looks like:
http://www.ebay.com/itm/Motion-Pro-Tappet-Feeler-Gauge-002-003-08-0052-Taotao-Roketa-SunL-Kazuma-/180988674961?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item2a23c40391
Offline Rigid
  • She likes a
    • KingCustomCycles
« Reply #4 on: February 02, 2013, 02:56:46 AM »
After about 500 times doing it you can estimate very closely by the amount of rattle when tugged on.  As mentioned above, a bent thickness gage, good lighting, and patience.
« Reply #5 on: February 02, 2013, 09:31:56 AM »
Those work very well.
« Reply #6 on: February 02, 2013, 09:46:33 AM »
+1...and it will last you a many years if you store it protected.
Offline Scott
  • 72 CB750
« Reply #7 on: February 02, 2013, 10:22:09 AM »
Thanks guys I'll give it one more go with these feeler gauges (modified ) then I'll track down the bent ones
Scott
