Author Topic: 1976 honda cb550 withe 750 carbs  (Read 890 times)
Offline blfellers
« on: February 02, 2013, 07:15:22 PM »
hello i have a 1976 honda cb550 with 750 carbs on it.  it had 120 size jets in and the plugs were black and sooty  with the air mixture screw all the way in. i put in 95's and the plugs still black and sooty after replacing them and mixture screw all the way screwed in as well. so today i put in 87.5 jets and the same thing is going on ....PLEASE HELP ME!! i just want to ride...also when the mixture screws are all the way in is that leaned out?
Offline Raef
Re: 1976 honda cb550 withe 750 carbs
« Reply #1 on: February 05, 2013, 11:09:22 AM »
The farther in the screws, the less air
Offline Raef
« Reply #2 on: February 05, 2013, 11:14:05 AM »
I have a 550 with some head and exhaust work and a single un oiled air filter. I run jets drilled to around 118 so it can work, but it depends on air filter resistance, exhaust back pressure, valve flow rates.....
