Author Topic: Wiring Dime City Reg/Rect. CB750  (Read 2322 times)
Offline sethdhawkins
« on: January 31, 2013, 08:20:23 AM »
Has anyone wired the above mentioned solid state unit into the CB750? I received the unit, but no instructions :-/ It appears to be slightly different than the one supplied by Ricks.
Here are the outputs on the Reg/rect:
3 yellows
Green
Red
Black
White
Any help would be appreciated.
Thanks,
Seth
All a man needs in this world is someone to love, if you can't give him that, give him hope, if you can't give him hope...just give him something to do!
1972-ish CB750K
1974 CB450
1974 CB360
1976 136' Ocean Going Tug
Offline 74750k4
Re: Wiring Dime City Reg/Rect. CB750
« Reply #1 on: January 31, 2013, 03:00:08 PM »
3 yellows                     ... go to the 3 yellows coming from the Alternator stator, inside the stock multipin plug on the stock harness. They were connected to the stock Rectifier.
Red                              ... to the battery + red wire
                                        The following three wires break out of the stock harness together, and were connected to the stock metal can regulator:
Green                          ...to the green wire coming from the ground side of the Field Coil winding. (This must also be grounded, or you get no field coil current&no alternator output.)
Black                           ...to the black wire from the key switch (Hot when key switch on), (provides hot for regulator, and field coil control voltage)
White                          ...to the Alternator Field coil positive side. This is your control voltage to the Field Coil.
AFAIK there is no ground contact at the alternator field coil. Therefore, the green wires must all be ground in the unmodified Factory harness.
Offline 74750k4
« Reply #2 on: January 31, 2013, 03:10:14 PM »
since your Dime City unit is actually an Electrosport ESR240, This:
http://forums.sohc4.net/index.php?topic=90786.0
Also applies...
Offline Ricky_Racer
« Reply #3 on: January 31, 2013, 04:04:06 PM »
« Reply #4 on: February 06, 2013, 12:27:49 AM »
Thanks gents! Great info.
Seth
1972-ish CB750K
1974 CB450
1974 CB360
