I was having an issue where the clutch would shudder from a stop to trying to start rolling. It felt like as I was letting out the lever the clutch would engage then disengage a few times then finally stay engaged, felt fine under rolling torque, no slipping. SO I figured maybe the discs were warped or weak springs. I installed new heavy duty springs and EBC discs last night, used the stock metal plates. The old discs had meat on them still and didn't seem warped that I could see anyway. They did seem like they had a glaze over them though. The springs were about 35mm long still but seemed soft.
Old stuff
New
The previous owner definitely worked on the clutch before, the lock nut wasn't tight in the least bit, the only thing really holding it on was the locking tabs that he thankfully bent over like a caveman.
While I had it out I decided to drill out a few more oil holes, and then I soda blasted all the grime off it.
Also shaped up some closed cell foam for my seat, its not perfect yet but will do the trick for now.
Flap disc on the angle grinder bit me a little bit while shaping that haha.
